Question about AOC LM520 (Gray, Silver) 15 in. Flat Panel LCD Monitor
Contrast window keeps on popping in the monitor
Hi guys, My problem is that my contrast window in the display keeps on popping everytime I turn on my computer. When I push the "auto" button in the monitor itself, it will dissapear but after a couple of seconds, it will pop again. How can I solve this problem. Kindly please help regarding this problem. Thanks guys.
    Brigadier General:
  • 6,966 Answers
Hi, it might be that a sensor in the monitor is sensing change in ambient light and therefore reacts by auto adjusting the contrast. when you push auto, it will do just that and auto react. Why not try manual and set it to your desired setting and let it run that way. But then again, of course it is possible that something is really wrong with the monitor and you would need a qualified service personnel to diagnose/repair it. Hope this be of some help and pls post again how things turn up. Kind regards.
Posted on May 18, 2007
SOURCE:
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
CONTRAST BOX KEEP POPPING UP AND I CAN'T GET RID OF IT
this due to the faulty micro controller of the monitor, its better take it to the technician
Jan 28, 2013 | E-Machines eMachines Desktop PC
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
A contrast screen keeps popping up on the monitor
Do you mean the monitor OSD ? ? it means the small buttons in your monitor has stuck .. probably the key is broken or dust would have been stuck the contrast key
Aug 31, 2010 | Dell Computers & Internet
Contrast window pops up and dims the screen.
You are not alone. I have a Viewsonic monitor that does exactly the same thing. Wasn't sure if it was the monitor or a "bug".
Dec 10, 2009 | ViewSonic VX910 19" LCD Monitor
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
There is no feasible way to fix this. The problem is a short in the circuitry of your flat screen. If the monitor is off warranty, it's cheaper to replace the monitor than to have it repaired.
Jun 02, 2009 | Dell Dimension 2400 PC Desktop
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 15 inch monitor, brightness/contrast window
The front panel switches are known to become leaky.You need to replace these switches.
Samir.
Please rate the solution and provide feedback.
Sep 28, 2008 | Computers & Internet
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
AOC LM520 (Gray, Silver) 15 in. Flat Panel LCD Monitor Logo
433 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
