Question about Earthquake Sound EQ-SWS12 Subwoofer
Earthquake eq-12 subwoofer parameters
Please,
i need parameters of these old sub woofers.
I bought twice almost 14 years ago!!
Thanks
Stefano from Rome (Italy)
    Scholar:
  • 45 Answers
I can't seem to locate the specs in my files or on line. From what I remember, you can use/build a sealed enclosure for each sub ranging from 1.5 to 2.5 cu.ft per sub. The larger boxes will play lower bass than the smaller ones at the expense of overall power handling and some efficiency. Ported boxes get a little more difficult but with some trial and error, they can be very effective. Even more so when tuned by the listeners own ear. Let me know if you need specifics on how to do this. Also General specs of your sub can be determined by knowledgeable audiophiles with a brief inspection. Perhaps a local electronics shop (if available) could help in this regard. Good luck and let me know if I can help further.
-Dynami
Posted on May 20, 2009
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Subwoofer buzzed extremely loud about 6 weeks ago as if it was getting feedback since then the subwoofer sound is muffled and distorted, not clean, i have checked all parameters on amplifier and these are...
your speakers were sitting to close to sub woofer and what happen was when puttind to batteries together what happens they move away from each other you blew your sub woofer the only thing to do now is replace subwoofer.
Feb 27, 2011 | Sony SA-VE835ED System
I need user manual of Wharfedale topaz SW-12. Where I find it. thaks
WHARFEDALE Topaz SW-12 Subwoofe
connected to Sony STR-DE975 at the sub-
woofer out-put only hums, ??
thanks
Sep 06, 2010 | Wharfedale Topaz SW-12 Subwoofer
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Earthquake Sound EQ-SWS12 Subwoofer Logo
626 people viewed this question
Top Earthquake Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Earthquake Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
