Question about Sanyo PLV-Z2 Multimedia Projector
Hey there, my Sanyo PLV-Z2 was starting to have blue dust on the image, so i decided to clean the lens and remove the lamp for inspection ,everything fine , but when i reinstalled my lamp the blue had went bigger and further, so i deide to open the projector , and clean it deeply with a air can every lens was blown by air with out touching it! now i re asemble the thing and i get a white image and when i press menu nothing comes up!
( hope this doesn't sound too simplistic, but go back and check all your connections.
Take the cover off again and make sure that the main circuit board on top is pressed on tightly in the area over the right-hand back side because there are two connectors there. Also, there are several other connectors that should be checked--two on the left side, and one just underneath the left side. Those are all the kind where several wires enter a small, hard, plastic rectangle that then plugs into a little socket.
I have the same model projector, but my blue lcd panel is burned out. The other solution I can offer is for me to buy yours from you and use it for parts in mine. Good luck.
Posted on Feb 08, 2009
Sanyo PLv - Z2 overheat reset button wont work
If the unit is overheating you will need to clean out all the dust from inside so the lamp can get air. Pushing the button won't clear out the dirt...
Oct 16, 2014 | Office Equipment & Supplies
Blue haze/fog all over screen
As it appears from the images that the images are fine. The sanyo PLV-Z2 is a LCD projector. So basically it projects 3 R G and B lights to make the screen. Yes it is definately not a LAMP issue. Either dust could have accumulated on the R and G panels thus leading to these prominent BLUE patches or if the LCD panels are damaged, u have to get the G or R replaced.. try running a application like Displaymate from "" and see which of the panels is exactly responsible for the problem. I think this should sort it out.
Dec 26, 2007 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLv - Z2 projector flashes multiple times on start up and then shuts down
Clean the unit, it maybe clogged with dust inside and the air can't get to the lamp.
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
Blue diust specs constellation like!
If you are seeing the "spots" when a black screen is projected, the problem is likely to be scattering caused by dust on the lens. If you can get at both ends of the lens assembly, clean both sides using lens tissue. If the spots are seen at all times, there may be damage to one or more of the LCD panels.
Please update this with your results of the cleaning.
Feb 04, 2010 | Sanyo PLV-Z2 Multimedia Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
New Sanyo PLV-Z2 not bright
is this original lamp or refurbished one or compatible some thing.
how was performance of previous lamp when you pull out it? if it is still working for few minutes, you can confirm projector by reinstalling it.
Sep 04, 2008 | Sanyo PLV-Z2 Multimedia Projector
LCD panel
The part is replaceable thru sanyo and the cost is $600 + shipping.
Sep 04, 2007 | Sanyo PLV-Z2 Multimedia Projector
Sanyo PLV-Z2 Multimedia Projector Logo
397 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
