Ok I now know there is not a belt to cause the tub to spin during the spin cycle. My tub doesn't spin the clothes out on the spin cycle. The clothes remain still. It doesn't matter if the door is open or shut the tub doesn't move. When the door is shut you can hear the pump pumping out the water so it can not be the door switch not being recognized right?? Is it gonna be the thrush bearing ??? Someone said it was a pin or a clip but how do I get to it? Thanks!!
-   My Crosley CW6000 does the same thing but if I open the lid and then close it again it starts to spin. I don't think that it is the lid sensor switch because it will stop the wash cycle if the lid is up. The washer will drin the water but the tub will not spin until you open and close the lid. Happens on either wash or rinse but only once per load. After that first time it works properly.
This is on a 4 or 5 year old light use machine in a summer home.-   RickD1245
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
My Crosley CW6000 will not drain water on the spin cycle, I lift the lid to see if it was draining,...
(More)
My Crosley CW6000 will not drain water on the spin cycle, I lift the lid to see if it was draining, it spins but never drain the water out. What could be the problem?
The machine will only spin if you give i a pull by hand to get it started then hold the tub to one...
(More)
The machine will only spin if you give i a pull by hand to get it started then hold the tub to one side it may keep spinning.
I would like to change the spark plugs on my 2003 Toyota Camry 4cyl but can't find them. Are they...
(More)
I would like to change the spark plugs on my 2003 Toyota Camry 4cyl but can't find them. Are they under the large black cover on the motor that says VVT-i, 16 valve? If so, I assume that it is easy to remove the cover and replace them? Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
