Question about Dell 926 All-In-One InkJet Printer
Paper jam in a dell 926 printer,
Need to open printer to remove paper, please send schematic or drawing to show proper sequence of removing screws to accomplish this
  • 1 more comment
  • 222444 Dec 30, 2008
    i need to get my jammed printer unjammed and working. plz help
  • pearlgirl901 Jan 14, 2009
    I used a 3" by 8" piece of paper and it won't come out.
  • sgkreidel Mar 14, 2009
    My 926 Keeps saying there is a paper jam but there is no paper in the machine.
I found help at these links and got it out by pushing it with a paper and then turning it off and then on again.
Posted on Jan 14, 2009
I bought one black and one color cartridge for my dell aio 926 printer...and it says there is a carrier jam. a checked and there is nothing blocking the papers path through the printer. can you please...
Did you actually open the unit up and search the unit thoroughly? I also had a jam error and after an in-depth search I found a little piece of paper the size of a dime! Was not easy to find or remove... Good luck!
Jul 18, 2011 | Dell 926 All-In-One InkJet Printer
Carriage jam on 926 dell printer
Here are some steps that can resolve your issue about paper jam.
Try to lift the paper exit tray, then remove the papers, then lower the paper tray and press the select button in the printer. If still the same, Raise the printer unit and check if there's a paper jam then try to remove it, close the printer unit and push the select button. If still the same try to open the access door in the back of the printer, remove the paper jammed, close it then push select button.
For more information about step by step procedure with visual click on the link.
Hope this will help your issue.
Thank you for choosing fixya
Mar 03, 2011 | Dell 962 Photo All-In-One InkJet Printer
Paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Dell 926 All-In-One InkJet Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
I have a Dell 926 all in one printer and it will not take the paper at all and if it does it jams up inside please help!!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 27, 2009 | Dell 926 All-In-One InkJet Printer
Paper jam
hmmm..I think there is a back door on that printer..try to open it on the back of the printer...
it will allow you to grab the jammed paper..^^
turn off the printer before grabbing the jammed paper..
May 07, 2009 | Dell 962 Photo All-In-One InkJet Printer
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the...
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
Dec 22, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
670 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
