Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Blower wont run right
Poulan blower will start easy but wont bring the rpm up when puy on high
  • Anonymous Feb 08, 2009
    Similar problem. Mine is tough to start. When it does run, it is low rpm, in full and half choke. With no choke, it cuts off.
  • kenp636 Feb 09, 2009
    I had a similar problem: started and ran OK but would stall and die when either the choke was opened all the way or if the gas flow was abruptly altered. I had a new carb kit (diaphragm) installed last spring and it worked like a charm -- but now (Feb'09) it's going back to its old ways, even though I followed the repair shop's advice and switched to premium gas.
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Posted on Nov 30, 2008
bbreton
  • 437 Answers
SOURCE: 25cc poulan leaf blower runs but will not rev
It may be old gas not allowing it to rev up. or the carburetor diaphragm may need replacing. I would say at 25cc engine is not going to sound or rev up like a more expensive blower.
Posted on Sep 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 25 Answers
SOURCE: can't start poulan ppbp 30 cc gas blower
At all? Check the plug to see if it's wet. If so you are getting fuel so problem is spark. Get a new plug and gap properly. What else have you tried?
Posted on May 06, 2012
I can't start my home lite 26b blower
Mike if the Blower wont start, it's not the High/Low Jets.
They only adjust High RPM running and the Low helps the carb transition from Idle to High rev.
Ethanol gas is a carburetor destroyer... Also, it eats the gas lines .
Jun 27, 2015 | Garden
What is the compression on a poulan leaf blower?
60 to 70 psi it will start fine. I fix Poulan blowers every day for a living
they are very easy to fix. A common problem is stuck piston ring.
Jul 10, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Blower vac runs at high speed but wont idle
Low speed circuit on carb is blocked. You can try using fresh fuel with some high quality cleaner added and run it through and see if it clear. Otherwise it means the carb has to be removed for cleaning. Which is especially hard these days with the EPA carb plugs on the mixing needles. These plugs are to minimize tampering by owners. You need to be a licensed shop with the tools to adjust the carbs and then put new tamper plugs on nowadays..
Be safe and good luck!
Jun 19, 2014 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Oct 30, 2009 | Echo Inc. 25.4 CC Backpack Blower
I have a Poulan gas blower that will not start. It is getting fuel, I have replaced the plug and coil. It looks like it has a weak spark, but does spark. Will not even fire with starting fluid.
Compression is zero, huh? Well the only thing that could cause that is the piston ring is stuck so that the right pressure never builds in the cylinder. These Poulan blowers are fairly easy to take apart, the hardest part is getting the plastic frame back together...lol! Keep me posted on your progress, parts are easy to get for these blowers. My suggestion to you is order a new piston ring and a gasket kit. Once you take it apart you will have to replace the gaskets and seals.
Oct 22, 2009 | Poulan Featherlite Gas Blower, with Low...
My weed eater blower starts and i can run the engine at full
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Jul 18, 2009 | Poulan Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
505 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
