Question about Kodak EasyShare V550 Digital Camera
Power issues ok here is the deal. my camera's redy light flashes red and then turns off. all i can find on this is change the batteries. well that doesnt fix the issue im having. this has happened before but it fixed itself rather quickly. this tine has been going on for awhile now so if someone could please help me out here. now remember its not a battery issue. thank you
    Genius:
  • 2,985 Answers
No it is a switching issue and is not going to get better. Kodak technical support will tell you more be prepared though -if you have had this for some time then the next camera purchase looms I guess
Posted on Jul 19, 2007
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
This should resolve the issue.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camera keeps turning itself off and the amber light keeps flashing
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists after changing the battery try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Battery and Charger problems
Only a new battery I venture what type of battery is it?
May 26, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
48 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
