Question about Destroyit 2602 Shredder
I have the 2602 model and the indicator for the door being open stays lit even when the door is closed is there a way to fix this
  • 35 Answers
Yes. There are two electromagnetic sensors (front and back). If defective, the main board will show a yellow or red light. These sensors function with the cabinet which is magnetized in the center (front and back).
Posted on Mar 03, 2009
Door open sensor
You have it backwards, when the wires are put together like you have done that indicates an open door to the module. When the door is closed it breaks the circuit and when open it makes the circuit. Pull the barrel around the plunger as far out as it goes and then close the door, then the switch is adjusted. Also since all doors have this switch how do you know you have the correct door??
Mar 24, 2014 | 2007 Hummer H3X
When i lock the doors the central locking will open them again and sometimes the stay closed abot 5 minutes till 1 houer
depending on what year make and model your vehicle is there are a few general possible causes. if the dome light stays on the whole time between you locking the doors and it auto unlocking, this usually indicates a faulty door pin switch, where even though the door is closed, the system thinks it's still open. or if it's a newer car there's a possibility the vehicle thinks the key is still in the ignition which could indicate any fault from a bad wire somewhere, to a bad body control module. and it's always possible that your security system module is faulty.
Feb 17, 2010 | Vehicle Parts & Accessories
Need help with craftsman 315 opener. this is a new install and the safety sensors are not working properly. even when they are not aligned properly, both the green and amber lites are lit solid,should...
Check to make sure you have them properly connected at the motor. The solid white wire from each sensor goes to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My indicator light on 2001 caravan for open door wont go off
I just went out and looked at mine and couldn't find the switch either. However I would reccomend going to each door (front back and tailgate and reshutting each one firmly.
Jun 24, 2009 | 2000 Dodge Caravan
The power flickers on and off after opening or closing
what happens if you plug a lamp into outlet. does it stay lit.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be
Dec 19, 2008 | 1996 Ford Taurus
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Last check on Whirlpool icemaker
No, when you open the freezer door the right side light will flash 2 times with a pause repeatedly. Then when you hold the left side flapper down it will stay lit. In other words, it will be on steady. You do not have to have the door switch closed. Catriver.
Jul 17, 2008 | Refrigerators
Destroyit 2602 Shredder Logo
290 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
