Question about Samsung HCL4715W 47" Rear Projection Television
SCREEN IS BLURRY WITH COLORS SCRAMBLED.
Trying to figure if this is something i can fix or what would be the estimated cost of fixing it.Sounds like a possible caibration ,the focus feature on the remote will not bring the colors back into sync.
  • 2 more comments
  • Anonymous Dec 31, 2008
    the three colors are not coming togeather like they should. images are blury.
  • goditshot Jan 06, 2009
    The Red Blue and Green colors on my Samsung HCL4715W are all stretched apart and when I try to manually converge them, the blue color will move but the red will not. I have tried for quite some time and it does not seem to be helping. Do I need an actual repair? The "Perfect Focus" function does not repair this problem. Can anyone help me?
  • Anonymous Jan 10, 2009
    I have the same issue, I think my red bulb is broken someone told me it was bulb problem . . . anyone found out the resolution?
  • sachinsaxena Mar 10, 2009
    i have a colour television since few days colours of tv are not coming as it should be all colours convert in red blue and green
    please giv e solution to this problem
    Problem Solver:
  • 12 Answers
You can buy the new convergence board assembly from Vance Baldwin and replace yourself. Its about $80 plus shipping.
Posted on Jan 15, 2009
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
Jun 22, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Hitachi 57F500 blurry picture
its the convergence problem in your tv.the ic needs replacement.to fix the problem.its worth getting it fixed.get it repaired.
the cost will be negligible.
Mar 21, 2009 | Hitachi 57F500 57" Rear Projection...
Power up fixed but still have scrambled colors
you will need to test some components at the tuner and check the tuner for any bad solder on it , although the tuner may be going bad testing the components around it may find the problem
Dec 29, 2008 | Polaroid FLM-3732 Television
Bottom of projection tube is another color
Yes, worth fixing, sounds like convergence is out on the tip ends. Check papers for Convergence controls. See if have auto fix.
Aug 12, 2007 | Philips 60PP9202 60" Rear Projection...
Blurry pictures, beep-click noise
Angie, You can call the repairs dept and they can give you a pretty good idea over the phone of how much it will cost. Their number is 800-706-2534 and then keep choosing option 1. They might ask you to send it in so they can look at it but they will send you an estimate of what it would cost to fix it before they do any work. If your camera will stay on long enough you can try resetting the camera but I doubt if that will do anything.
Jul 09, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Samsung HCL4715W 47" Rear Projection Television Logo
161 people viewed this question
Henry  Thomas
Henry Thomas
