I cannot seem to scan from my Canon MX700 to my iMac. I have reinstalled the drivers from the disk.  The scan button appears but when I click it says "scan filed".  When I try it through the software, it lists the printer but not the scanner.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I never had problems w/this using OS 10.5. I installed 10.6 and it seems to have undone so many settings. Having said that, I never noticed that the 'use scanner driver' box had become unchecked. I'd been trying everything possible to fix the problem, and the ONLY problem was an unchecked box. Take a look. Make sure it's checked. Also, my iMac is getting sluggish - took a really long time for the scanner window to open. At first I thought it wasn't working.
I realized my mistake by searching in spotlight for ScanGear and the MP470 series Scanning Guide opened up. Followed through guide and * doh * problem was staring right at me. ** smh **
Posted on Mar 19, 2013
I cannot scan from my Pixma mx700. I have an imac, reinstalled software, downloaded new drivers...HELP
Posted on Dec 16, 2010
What is the profile of the mx700? On my desktop I could Click on mx700 and then scan to e-mail. On my laptop the want to know the profile.
Hello!
It only means that driver of Canon MX700 is not compatible with the operating system of your laptop.
Download the drivers from the link below:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#DriversAndSoftware
Make sure to select the correct operating system, then click the Drivers.
Good Luck!
Alpug
Sep 22, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I have a i mack and a canon mx700 cant get it to print
hello, please ensure that all of your apple software is up-to-date on your imac and that you have installed all of the canon software for mac. in your utilities you will have an add printer option and the your canon model should be listed there , select it and you should then be able to print.
Oct 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 scanner wont scan
just uninstall the driver software and re install it.
Sep 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
We are experiencing a problem with scanning.
Ok... not sure if this resolves the issue for brigitteserr but just some general tips.
The Scan button will only work if you have installed a suitable scanner based software packed on your computer. As a general rule this is the Navigator software for your Canon model as provided with your driver disk (or on the Canon website).
Personally I would recommend that instead of using the scan button on the printer, you initiate any scanning from your software and then work from there as all the scan button does is initialise the program and nothing else.
Hope that helps.
Jan 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I lost the software for my PIXMA MX700 and need to reinstall it
Dear Roadscholar1,
You can find the drivers and all the software available for download at the url below.
http://www.canon.com.au/drivers/default.aspx
Follow the prompts and enter your model.
Gremlin11
Dec 02, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Im having problems with my canon printer
I'm not exactly sure what causes this problem, but here is what I did to solve it on the Canon MX850.
Go to Canon, search for your printer model (I searched for MX850, but you would do MX700), click drivers and downloads, and download the IJ Network Driver as well as the MX700 series MP Driver.
Install the IJ Network Driver first. It will require the printer be connected via USB, even if you use a network. Then install the MP Driver.
After that I was able to scan to the computer.
Nov 30, 2008 | Office Equipment & Supplies
Lost software cd
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:PIXMA MX700 office all in one inkjet printer
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file, double click on the file , then if you getintroubles,followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:someprinterdoesnot work on Vista, if you do not find any driverdownloadfor Vistaonyour model page, that means your model is not Vistacompatible.
Oct 27, 2008 | Canon MX700 Office All-In-One InkJet...
Canon Pixma MX700 Scanner Problem
I was having the same problem, and thanks to the person who posted solution number two which simply highlighted the fact that the apparently software that came with the Canon Pixma MX700 unit is not compatible with Window Vista.
The reason I was confused is because the printer was working perfectly fine across the network, but when I went to scan my computer would tell me that it can't communicate with the scanner. I'm thinking ... "well since you can communicate with the printer, you should be able to communicate with the scanner, after all, they're the same device!"
As a workaround, I used a third party program to do the scan (in this case, Photoshop) and everything worked fine. If you have Photoshop, just go to file > import to start the scan. If you don't have Photoshop, I would think whatever program you are using for image editing may have the same functionality.
Hope that helps,
Brian
Jun 09, 2008 | Canon PIXMA MX700 All-In-One InkJet...
109 people viewed this question
jasbo
jasbo
