Question about Garmin GPS
The plug into our Garmin Street Pilot is not connecting
The plug is no longer making a connection into the Garmin. Not the plug into the power, I believe. It slowly went out. We tried using tape to keep the connection, but that no longer works. Can we replace the plug or how can we check if it is the receiving connection on the Garmin. Is this repairable?
I got a hold of a tech. They are replacing the vehicle power plug and the mount. I didn't think it would be replaced for free because of the warranty not being in effect, but they are. Thank you for responding to my request.
Posted on Dec 30, 2008
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Attempts to install Garmin c330
there might be an problem with you street pilot, but try to download this software go to this webpage
that will keep your unitr up to date and fix any problems you might have with it
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
Power plug broken, missing parts to get power
Eloise, did you ever find a solution to this problem with yur Garmin? I have the same problem and don't want to spend $40 for an entire mount. Let me know, you can email me at Thanks!
Mar 28, 2010 | Garmin StreetPilot C330 GPS Receiver
Connection problem maybe ? im not sure
make sure that you have the garmin driver downloaded onto your pc
Nov 12, 2008 | Garmin StreetPilot i3 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a garmin i3 street pilot, and recently broke the charger conection on the head set is there any service centre locations where i could get it fixed in ireland thanks conor
The street Pilot Series also has a side connection for the computer with the mini-USB cable that you can plug a Nuvi charger into and it will work and charge the unit.
May 09, 2008 | GPS
Garmin 330 street pilot keeps shutting down. Only 3 mos. old and has been connected to cigarette lighter. What is the problem? I need a manual.
Make sure that you age getting power from the plugin.
Test: With the unit OFF plug adapter into cigarette lighter.
The Garmin should turn on automatically. If it does not,
you are not getting power to the unit. Make sure you have
good connection at the holder.
Generally it powers off by itself because it is not receiving
power from the plug.
Oct 22, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
53 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
