Question about Vivitar ViviCam 3785 Digital Camera
Have a vivitar 3785 , it is new with a new memory card , says c
It says card is full , but we have not taken any pictures yet , have tried formatting the card but that did not help either.
  • dndsliladora Jan 17, 2009
    I ALSO HAVE THIS SAME CAMERA I BOUGHT A NEW SD FOR IT THAT WHEN IN PLACE SAYS THE CARD IS FULL, BUT I PUT A SMALLER SD IN IT AND IT WORKED FINE. I THINK THE 2GB SD IS TOO MUCH FOR THIS CAMERA
We had the same problem. Our solution is that the camera is not able to regonize a chip larger than 512 MB. When we took pictures that we had on the smaller card that we had downloaded to our computer, put in the larger card in the computer and dragged the picture into the bigger card. It still would not display on the camera, but it will show on the computer and it works in a digital picture frame. I hope this made since, if you have any other questions, please email us at johnandsheri@yahoo.com
Posted on Jan 24, 2009
I replACED MY MEMORY CARD WITH NEW SD 2gb CARD AND NOW IT SAYS MEMORY FULL AND THERE ARE NO PICS ON IT... HELP
make sure the lock on the side of the memory card is in the unlock position. sometimes they will lock when inserted into camera. good luck.
Dec 07, 2010 | Vivitar ViviCam 3785 Digital Camera
Added new memory card. Camera says that the memory card is full..How do I correct this?
Assuming it is not actually full, this might mean the card is incompatible with the camera (too high a capacity) or it might mean it needs formatting. Usually a camera will say if it needs formatting, so I would check the camera specs to see whether you have a memory size it can handle. SDHC cards are not backwards compatible with SD cards.
Oct 22, 2010 | Vivitar ViviCam 3785 Digital Camera
Hi Sir
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Dec 29, 2008 | Vivitar ViviCam 3785 Digital Camera
When i try to view my pictures a memory error comes up.
most likely the memory you are using is either corrupted or not damaged, try using a diferent one similar to the SD card you are using...
cheers
Dec 15, 2008 | Vivitar ViviCam 3785 Digital Camera
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
I can't find the memory card slot on th 3785 camera. where is it.
I checked out the user manual and it looks like the SD memory card slot is located right next to the battery. Just open the battery compartment and look near the hinge and you will see a place to put an SD memory card. Here is a link to a pdf version of the manual which is nice to have even if you have the printed version:
Click HERE.
Take Care,
-WN
Aug 19, 2008 | Vivitar ViviCam 3785 Digital Camera
Pictures cant be viewed says no image-then wont take pics says card full?
try the memory card in a card reader and plug it into a computer. see if the computer can detect the card and the contents in it. if it does detect it then that means there is a problem with the camera not recognizing the card or files in it. if it does not detect it in the computer that means the memory card of the camera is the one having problems.
Jun 09, 2008 | Vivitar ViviCam 3785 Digital Camera
Vivitar vivicam 3785 new memory card
Might be that the card is too large/small for camera to recognize, or it is a newer type of memory. Look up the specs for camera and compare to stats of memory card.
Nov 13, 2017 | Vivitar ViviCam 3785 Digital Camera
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
267 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
