Question about Zanussi FJS1225W Front Load Washer
Rmoval of back panel- Kenmore top loading washing machine
I removed the two console end caps and two screws on the top of the rear panel (one at each end). There appears to be a type of metal clip that is attached to the rear panel but I have not been able to remove them. Is the removal of these clips the only thing I need to do to remove the rear panel? My goal is to replace the lid switch, the part of which I purchased.
I would appreciate your help.
Thanks,
Nelson
  • Zanussi Master
  • 3,463 Answers
In your browser bar type in youtube.com
Then in the search box type in ; repairing kenmore dryer
Then click on the video you want ,they run in sequence.
This should solve your prob.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
HI THERE, IT SOUNDS AS IF YOUR PUMP IS BLOCKED, NOT WORKING OR SOMETHING MORE SERIOUS. START BY CHECKING THE PUMPS IS NOT BLOCKED, LOOSE CHANGE NORMALLY CAUSES THIS AND IS RELATIVELY EASY TO FIX.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
May 04, 2011 | Kenmore Washing Machines
Working on a Kenmore 80 series (11020872990) washing machine, do you remove the rear panel or the front/sides panel?
no don't touch the back at all.unplug it,then pop off the white end caps on the console and remove the two phillips screws,lift up the console,unplug the lid switch connection in the top middle and with a screw driver pop off the metal clips,just stick the screw driver in the hole and on top of the clip and just push towards the back wall and it will pop out,then open the lid and tilt the frame forwards and back at you and remove the hole outside frame.what problem are you having?let me know how you make out
Oct 16, 2010 | Kenmore 22642 Top Load Washer
Have Kenmore Elite top-loading washer that will not agitate or spin. told it is probably the coupling between motor and transmission. can't get control panel off.
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Where is the pressure switch located on the kenmore washer?
If this is a Kenmore washer as the one you have this question posted under, the pressure switch is located inside the operator console directly behind the load level/load size selector knob. You can access it by removing the back on the console. If the console does not have a removeable back, it will lift up by one of the following means:
1. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
2. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. On some models, there is a screw in the back of the console on each that you loosen. With the screws loosened, the console with slide forward a little, then lift up.
With the console accessed, the pressure switch is a round cookie shaped device with an electrical connection and a small air hose attached.
If you are uncertain of how to access the switch, please post back with a complete model number (located on a nameplate around the wash tub opening under the lid) so that I may be able to provide you with better assistance.
If you need further assistance, please let me know. I hope this helps you.
Is there a reason why you need to access the pressure swtich?
Oct 15, 2009 | Kenmore 23822 Top Load Washer
Top load kenmore heavy duty 70 will not drain
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 20, 2009 | Kenmore Washing Machines
How do I remove the control panel? on the kenmore elite calypso
Mar 30, 2009 | Kenmore 24082 Top Load Washer
Can't remove end caps from Whirlpool Model GST9679PG1 top loader
take the two screws out.one on each side.then stand in front of machine and pull caps forward and up and your face of the machine will be up.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
I need to remove the back panel on my top load kenmore washer
5
6
7
Jan 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Remove console
The console can be removed in a few different ways depending on your model number:
3. Some consoles have screws in the back that require removing before the entire panel will slide forward, then lift back.
You should post back with your COMPLETE model number (located on a nameplate under along the wash tub opening under the lid) if you ruin into any difficulties. I hope this helps you.
PS Is there a reason why you are removing the console?
Aug 07, 2008 | Kenmore 24032\24036 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
67 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
