Question about HP PSC 1401 All-In-One Printer
When I click on print and the next screen that comes up is the print screen with the number of copies I want. It has been set to 12 and I have to manually change it every time I print. I want it set back to 1.It is a HP PSC 1401.
    President:
  • 2,692 Answers
My windows 8.1 computer printing menu(page setup) doesn't ask me the number of copies I want and my monochrome laser printer doesn't stop printing.how can this be corrected ? please answer and/or corr
The setting for number of pages usually can be set from within the printers software. Or when you go to print check Print Preview and try setting it from there. Normally a printer wont print more pages than the amount you are attempting to print.
Feb 14, 2015 | Microsoft Windows 8.1 64-Bit - System...
Tip
Configuring NETGEAR print server PS121 printer port settings manually.
If you can not run the installation software for the print server PS121 on the computer then you can try the below steps to manually configure the printer port settings:
Step 1:-
1. Visit the link below to make sure that the printer is in compatibility list:
http://kbserver.NETGEAR.com/kb_web_files/n101216.asp
2. Make sure that the printer is working in direct connection with the computer.
Step 2:-
1. Now connect the printer to the USB port of the printserver and then the Ethernet cable from the router to the Printserver Ethernet port.
2. Press the DIAGNOSTIC tool button on the printserver for 10 sec (All the lights will blink amber), you will receive a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router. If there is no ip address then powercycle the router, printserver and the printer. Press the diagnostic tool button again.
Configure printer port settings on XP computer:
1. Go to control panel then go to printer and faxes.
2. Right click on the printer icon go to properties.
3. Click on the ports tab on the top.
4. Click on add port.
5. Select standard TCP/IP port and click on new port.
6. Press next.
7. Enter the IP address of the print server it will show you the port (IP_ip address).
8. Press next.
9. Select the second option custom and click on settings button.
10. Select the protocol as LPR; enter the queue name as q1.
11. Select LPR byte counting enable.
12. Click on ok and press next then click on finish.
Configure printer port settings on VISTA computer:
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
These steps will help manually configure the printer port settings on the computer.
on Feb 10, 2010 | NetGear PS121 Print Server
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
My brother 2070W acts like it receives the data, but it never prints
When reconnecting the USB cable to the computer or laptop the cable must
be reconnected to the same USB port it was previously connected to. Otherwise, Windows will install another copy of the printer
driver and the printer will no longer print. Most computers have two or
more USB ports. To prevent this problem from occurring we would
recommend labeling the end of the USB cable to indicate which USB port
the cable must be reconnected to.
To resume printing the printer driver should be removed then
reinstalled.
In Windows 2000 open Start, Settings and Printers. In Windows XP open
Printers and Faxes. Double click one of the Brother printer icons to
open the print queue. If print jobs are listed click Printer and Cancel
All Documents. Repeat this process for all copies of the Brother printer
driver.
Delete all copies of the Brother printer driver by selecting the printer
and clicking File then Delete.
Once all the copies of the Brother printer driver have been deleted
click File and Server Properties. Click the Drivers tab. Select the
Brother printer from the list and click the Remove button. Click Close.
The printer driver can be reinstalled using the Brother CD-ROM or
downloaded from the Brother Solutions web site. Check the CD-ROM to
verify it lists the operating system installed on your computer. If your
operatingsystem is listed insert the CD-ROM and install the printer driver.Before installing the printer driver disconnect the USB
cable from the back of the printer. Do not reconnect the USB cable to
the printer until the installation prompts you.
If the CD-ROM does not list the operating system installed on your
computer the CD-ROM should not be used to reinstall the printer driver.
The newest version of the printer driver is available for free download
from the web site below.
http://solutions.brother.com/model_list/mono_laser_us.html
How to install the downloaded driver:
1. Download and save the Windows 2000/XP driver to your desktop.
2. Once downloading is complete, Double-click the file to open the
WinZip Self-Extractor. In the Unzip To folder section, change the path
to c:ro, click Unzip and click OK. Click Close to close the WinZip
screen.
3. Open Printers or Printers and Faxes.
4. Click Add Printer or Add A Printer.
5. Click Next on the first screen. Select Local printer. Remove the
check from Automatically detect and install my Plug and Play printer and
click on Next.
6. Select a USB port and click on Next.
7. Click the Have Disk button and type the directory c:ro.
8. Click on OK.
9. Select the model and click on Next.
10. Select Yes to use the printer was the default printer then click
Next.
11. Select Do not share this printer or Share as and click on Next.
12. Click on Yes or No to print a test page.
13. Click on Finish to complete the installation.
Do give my solution the highest rating if it solves your problem. Thank you for using fixya.
Aug 04, 2009 | Brother Office Equipment & Supplies
Suddenly the HP PSC 1600 is printing at supe slow speeds
TRY THIS
first try to copy something to check that the hardware function is fine if copy comes out fine try the following step
click on start button go to control panel open printers and faxes select your printer name right click on it and go to properties click on advance tab now select print processor and select WINPRINT and then RAW
now click ok and try printing
if still does the same thing then goto control panel printers and faxes and then click on add a printer select ADD A LOCAL PRINTER now select existing potr and select usb 001 click next select the brand HP and then DESKJET 990c in the printer list click next give your printer name and select set as default now click next and finish the installation now try printing
Jul 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Connected, but cannot install and print
Thank you for contacting Fixya.
Please install the Lexmark printer on Windows XP using the "Add Printer Wizard" by following the steps given below:
1. Go to "Start," "Control Panel" and "Printers and Faxes."
2. Click on "Add Printer" and then click "Next."
3. Select "Local Printer" and then click "Next."
4. Select the required Port (USB001 Virtual Printer Port if the printer has already been connected) and click "Next."
Note: If the printer has not been connected, select "File."
5. Click the "Have Disk" button.
6. When the "Install From Disk" screen appears, click "Browse."
7. From the "Locate File" screen, in the "Look In" option, select "Drivers."
8. Click "Open" and then click "OK" in the next screen.
9. When the name Lexmark printer is displayed, click "Next."
10. Leave the name as Lexmark printer and choose whether or not you want the printer to be the default.
11. Indicate whether or not you want to print a "Test Page."
Note: This is the "Windows Test Page." It won't be printed before the cartridges are selected.
12. Click on "Finish." The printer files will then start to copy from the CD.
13. Please follow the on-screen instructions to finish installing the printer.
Sincerely,
Jeeth
Apr 12, 2009 | Lexmark X6170 All-In-One InkJet Printer
Computer not accepting printer
your's tech expert
Jeeth
Mar 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Trying to print multiple copies and only one copy prints
Hi, my name is Juanita and I will try to help you with your problem.
What kind of printer do you have? And when you say you can't print multiple copies, is it the problem with setting the number of copies in the print dialogue box, or is it the problem for printer settings?
For this problem, I contacted the Inti Prima Karya. It is a cheap printing solution for all your printing needs. It would be much cheaper to use their offset printing solution.
Nov 05, 2017 | HP DeskJet 6122 InkJet Printer
How to make labels from EXCEL list?
Hi-
Im not really familiar how to make label on Excel but you can try this steps that works on words:
Please follow the steps below to print Business Cards or Labels in Microsoft Word.
1) Click on TOOLS.
2) Click on ENVELOPES AND LABELS.
3) Click on the LABELS tab.
4) Click on OPTIONS.
5) Under PRINTER INFORMATION select LASER AND INKJET.
6) Under product number select the label type that you are using. If you are using Avery labels, select the number that coincides with the number on the Avery package.
7) Click on OK.
8) Click on NEW DOCUMENT.
9) This will give you the layout of the document format on your screen.
10) Type in all the information you need on one label.
11) Once the label is completed, highlight that whole label.
12) Click on EDIT, COPY.
13) Click on the next label.
14) Click on EDIT, PASTE.
15) Paste the information on all labels until page is completed.
16) Print your labels.
With this procedure, you do not need to modify the page setup or printer driver properties.
Hope this help, pls rate as fixya if this helps. Thanks!
Jun 26, 2008 | Computers & Internet
HP PSC 1401 All-In-One Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
