Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Problems adding new MAC address
I have a desktop computer directly wired (LAN connection) to a cable modem via the G Plus MIMO router with three laptops i have previously added to the WAN via their MAC address. i'm trying to add another MAC address currently and every time i try, the router seems to drop all internet connections on all computers, even the LAN. help!
  • 4 more comments
  • KYLE L Dec 30, 2008
    yeah, i agree about losing the LAN. i have tried both "allow" and "apply changes" separately and i didn't matter which i clicked, each time i click to attempt adding the address, it just drops all internet connections and i have to reboot the modem and router. now when i try to go back into the router and try your suggestions above, i get the attached message which may be from another computer on my network or someone that's trying to piggyback onto my network:
    it seems that message was from one of the laptops on the network that i logged on with last. i ended up doing a hard reset and rebooting a few times. this allowed me to connect again with the router with the desktop. then i tried updating the firmware. the router dropped everything again. at this point is seemed to me like a computer issue, not a router issue. i rebooted a few times to get a connection again and tried the same thing with IE instead of my Firefox browser and it worked. I then went back to add all the MAC addresses and it worked with IE. I'm now up and running with all computers on the WAN and LAN. thanks for your efforts but please keep this issue in mind for anyone you may help in the future.
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    Heres the solution: turn off all computers and routers and etc... even the modem... With all equipment off, turn on the main router first. Then turn on the modem... it will search for the mac address and find the router's mac address. let it boot up and then go and turn on everything else... that should eliminate all the drops when using any of the equipment... the problem usually is that the modem looks for ONE mac address and only one. So if the router is that one address, then all the others should work ok.... Let me know how it goes and if you need any other help.
  • eecom May 11, 2010
    Excellent. Many thanks for posting again: it helps everyone to learn what solved the problem and which variable might have created it. ATB
    OK....normally a hard reset would be in order, but this message may just be a Belkin oddity.
    Try switching off all computers, then reboot the router. When the router LEDs are showing as ready, switch on a computer which has a wired connection to the router. Can you login now, or is the message the same?
    Hi...It's strange to lose the LAN as well. Can I ask if you added the new computer's MAC address under the 'Wireless -> MAC address control' section: then clicked the 'Allow' button, added the address, clicked 'Add' then 'Apply changes'? Apologies if you have done all this - it's just that looking at the manual, there is a lot of potential for error as far as I can see....
    If you have done this, you could try disabling MAC filtering and see if you can connect then. This might narrow down the problem.
    I'm also wondering if you have a new ISP and/or have had to enter a WAN MAC address (under Internet WAN > MAC address).
  • 1,305 Answers
Ok... this is an easy fix..first, turn off all the equipment including any laptops with wi-fi. then TURN ON YOUR MAIN ROUTER FIRST. Secondly turn on the cable modem..be sure its connected to the already turned on router. This will establish the router as your address the cable modem will set up as the main mac address. Then go ahead and boot up any other routers, and computers and wifi... That should keep everything connected because the router will delegate all the addresses to everything and the modem should remain "happy" with the router addres..
Let me know if this helps... and if you need anymore help.
Posted on May 13, 2009
2 Suggested Answers
mspcrepair
  • 169 Answers
SOURCE: arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Posted on Sep 29, 2008
Belkin F5D7234-4 V5 MODEM LIGHT AND INTERNET LIGHT ARE BLANK. WHEN I RUN A CABLE FROM MY MODEM TOMY COMPUTER, INTERNET WORKS, BUT WHEN I CONNECT THE CABLE FROM THE MOEM TO THE BELKIN WIRELESS ROUTER, NO...
Is this a new router - or should I say did you only have the one computer hooked to the modem until now? Some ISPs use the MAC address of the installed PC to assign the network IP address. Since the Router will have a different MAC address, the modem will not recognize it. ISPs use this as security, but it makes networking impossible. However, most routers have a feature called MAC spoofing, which allows the Router to fake the modem into believing it is the computer originally attached to the modem. On newer routers this is a feature that can be automatically done during the setup wizard. You need to have the original PC hooked to one of the router ports (not WAN or INTERNET) and when the router asks you if you want to use the MAC spoof, say yes.
Oct 23, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
I have a Belkin Wireless G Plus Router connected via Ethernet cable to a Scientific Atlanta cable modem supplied by Virgin. I can't currently get any signal from the Belkin to my MacBook Pro (I've got it...
Make sure the IP of the Router and the IP of the MAC is in the same scope.
E.G. Router: 192.168.1.1 Subnet 255.255.255.0
Mac: 192.168.1.5 subnet 255.255.255.0
Typically the router acts as DHCP-server and distributing ip-adresses automatically, when a computer is connected. But the the IP can also be set manually.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Adapter wire troubleshooting
Cable modems often don't work with a router unless you do something called cloning your MAC address. The MAC address is a unique number assigned to each device's network connection. Unless the cable modem sees the MAC address of the computer originally used to set up service it often won't connect. Cloning the MAC address in the router gives it the same address as your computer, and that usually gets the connection going.
You'll find the link for cloning the MAC address in the router setup screens. Rather than go through the steps here, I suggest you download the manual for your version from Belkin or look at the copy on the CD that came with the router. I don't know which version of the router you have, so the manual I was looking at may not be exactly the same as yours.
Make sure you have the computer originally used to set up your cable Internet service connected to one of the router's wired ports. Follow the steps in the Alternate Setup section to move through the various screens until you reach the link to change the MAC address, and that's where you'll copy the address from your computer to the router. Once that's done your modem and the router should play nice together, and you'll be back online.
Hope this helps, and thanks for using Fixya!
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I'm trying to set up a new laptop to my belkin router
When you first setup a wireless router you need to connect the wireless router to the computer with a LAN cable.
Then you open a browser such as Microsoft Internet Explorer and on the address bar you type the IP configuration address of the wireless router eg. for Belkin wireless router it is http://192.168.2.1
Enter the default login name and password.
You should change the password and you should setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the router.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Arimex comcast router won't talk to belkin wireless g plus mimo router
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot run internet with my router
downgrade your vista to windows XP Pro or XP home..
Nov 07, 2007 | Belkin (F5D8231-4) Wireless Router...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
188 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
