Question about Dell Inspiron 1150 Notebook
Power failure inspiron 1150 works fine on battery. taskbar indicates that battery is chargingnbut it isn't. strength keeps exhausting. now down to 15%. when I remove the battery, the screen is blank and the two end lights keep blinking. the keyboard is dead, none of the keys respond. I,ve checked the adapter and it is putting out 19 volts dc as it should.. any help will be very appreciated. either here or my Email.(
  • harrypal Dec 29, 2008
    there is nothing wrong with the battery. the problem i that the computer does not boot up on powerand the keyboard is frozen dead. the computer operates fine on battery which is being exhausted because no power is getting to it.
  • harrypal Dec 30, 2008
    The problem was apparently caused by memory failure which I fixed. All is working fine. Thanks for the help.
  • 413 Answers
If it is an older battery it probably needs to be replaced. Sometimes when you remove a battery while the computer is running it makes it "freak out". Not mch you can do to test this except try a new one.
Posted on Dec 29, 2008
  • Dan rogers
    Dan rogers Dec 30, 2008
    The computer needs to go back to the manufacturer or to a professional because apparently the leads that charge the battery have become faulty
I have a dell inspiron 1150 when i connect the charger the battery and the power light keeps on blinking and nothing happens oh turning the power button
Sounds like the adapter is being overloaded ... Dell is one of 2 or 3 manufacturers using a 3 wire adapter plug jack. And ... well ... lets say they can be problematic ... it's a great system but very sensitive to battery malfunctions. I suggest you remove the battery then pug the adapter in ... if all is OK then have the battery checked
Feb 23, 2011 | Dell Inspiron 1150 Notebook
I have a dell inspiron 1150. It had an error... something to do with the fatal battery. Can't remember the code. I found the code online and it indicated that it was for a small 2032 batttery. I took...
The CMOS batter could have been solder onto the motherboard. In most laptops, the batteries are not removable. They only power the BIOS settings (time, date, computer configuration, etc.) They do not power the LCD.
Sounds like you have something else wrong.
I don't get paid for advice so if this answers your problem, I would appreciate 4 thumbs.
Sep 20, 2010 | Dell Inspiron 1150 Notebook
Inspiron 1150 won't turn on. Noticed recently that battery life seemed shorter, plugging it in did not prevent it from shutting down after receiving the low battery warning, and it took a long time to re...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 18, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
Jul 27, 2009 | Dell Inspiron 1150 Notebook
Dell Inspiron 1150 - Wont boot & nothing on screen ??
The fans on this unit are thermostatically controlled and only turn on when the predefined processor temperature is reached, so upon turning the unit on It will spin up too full speed and then seem to shut down until it is needed.
If you are getting no beep tones and since you have already tested your memory, I am forced to assume that either your processor has retired or your cmos is wrong, Since you sound like you have already opened the unit then locate the clear cmos jumper/switch on the board and clear your cmos which will reset to defaults.....if you still have the same problem then I reccomend trying a different processor.
Ed Meyer
May 24, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
1150 won turns on then shuts off
Intermittent power on and off indicates a power supply failure. Check your power supply to make sure if it is working fine.
Oct 06, 2008 | Dell Inspiron 1150 Notebook
Dell inspirion 1150 won't boot up
I had this exact same thing happen. I tried everything I could think of and find out to try. For me it was a motherboard failure and installing a new one worked. .
Jan 19, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 1150 Wont Start Up
try taking out the can have the instructions by going to this link--- that does not work than i would suggest to get the motherboard replaced.You can contact the tech support incase you have the warranties and get it replaced
Dec 22, 2007 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 1150 Notebook Logo
Alun Cox
