Question about Canon i860 InkJet Photo Printer
Ink won't dry
My photoprinter (Canon i860) all of a sudden started printing pictures on which the ink won't dry. Even if I leave them overnight the ink is not drying. What's up?
  • Jan Kornstad Apr 29, 2007
    Thanks "z". We had already checked out all the paper possibilities - quality, wrong side, etc. Someone suggested something about the ink not being sealed by the right amount of heat????
  • 247 Answers
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Posted on Apr 29, 2007
My printer won't print black ink.
If you had not replace your black cartridge with a new one it is possible that the ink is empty.or the ink head is clogged.dip the printhead into a warm water do not emerge just the print head then wipe it with a tissue to dry repeat until the ink is ok..
Aug 19, 2011 | Canon i860 InkJet Photo Printer
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
My Canon I860 has stopped printing any of the colors. When printing a color picture, the printing takes an extra long time and then only the black colors are printed.
To solve the problem follow the mentioned stages bellow:
1.Click start, then printer and fax icon
2.click maintenance tab, then clic ink cartridge setting
3. Select auto dedection or Black and colour cartridge.
Then cloge all.
Thank you.
Aug 27, 2010 | Canon i860 InkJet Photo Printer
Canon S520 Printer won't print black!
Hi.
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
Dec 30, 2017 | Canon S520 InkJet Printer
Color not correct and lines in print
Have you tried the cleaning function? It is usually accessed via the Canon software that you would have loaded when you first installed it on your computer.
See Canon instructions:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9387&kbpage=yes
Have a look here:
http://www.fixyourownprinter.com/forums/inkjet/59376
and here:
http://www.howtofixcomputers.com/forums/how-guides/canon-i860-print-head-removal-cleaning-210868.html
If you don't use the printer regularly the ink can dry up block the 'very' small inkjet nozzles. Occasionally people have problems when using generic non-genuine ink cartridges, but I have much experince with re-filling Canon ink cartridges and they are much more user friendly then the durabrite ink cartridges used in Epson printers.
Cheers,
Steve
Feb 16, 2010 | Canon i860 InkJet Photo Printer
Print Head Alignment test produces only a blank page.
Yes head probably clogged. You can try cleaning head multiple times, I think this is a pigment ink machine, so get only these carts for it
Apr 25, 2009 | Canon i860 InkJet Photo Printer
Photo print quality Canon i860
You might be running low on toner or ink. In this case check out the ink/toner capacity left. it might even be a faulty cartridge if bought new, or a faulty printer, but it doesn't sound like it.
Dec 27, 2008 | Canon i860 InkJet Photo Printer
Prints suddenly red & cleaning doesn't help
The Color printer catridge ink might be low . You nned to replace.
Dec 15, 2008 | Canon i860 InkJet Photo Printer
I have just got a Canon Pixma iP4500 but as I use a Mac with leopard OS X 10.5.4 I have had great difficulty with the Easy-PhotoPrint EX that I had to download. When I want to select a photo to print only...
Mac OS X v10.5 Compatibility For Mac OS X v10.5 compatibility, see below:
<Supported models>
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP2600, iP3000, iP3300, iP3500, iP4000, iP4000R, iP4200, iP4300, iP4500, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, mini320, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
<Supported software>
- Printer driver
- Memory Card Utility
- Network Tool
- Setup Utility
- Easy-PhotoPrint
- Easy-PhotoPrint Pro
- Color Management Tool Pro
- Easy-PhotoPrint EX
<Usage>
To use with Mac OS X v10.5, download the latest version of the software from the Canon Web site.
For Easy-PhotoPrint and Easy-PhotoPrint Pro, use the counter-measured version available for download.
The following models, the printer driver is included in the OS.
BJC-2100, BJC-8200, BJC-85, DS700, DS810, i250, i320, i350, i450, i455, i470D, i475D, i550, i560, i70, i80, i850, i860, i900D, i9100, i950, i960, i9900, iP1500, iP1600, iP1700, iP1800, iP2000, iP3000, iP3300, iP4000, iP4000R, iP4200, iP4300, iP5000, iP5200, iP5200R, iP6000D, iP6210D, iP6220D, iP6310D, iP6600D, iP6700D, iP8500, iP90, iP90v, mini260, Pro9000, Pro9500, S200, S300, S330, S400, S450, S500, S520, S530D, S600, S630, S750, S800, S820, S820D, S830D, S900, S9000
Jul 17, 2008 | Canon Office Equipment & Supplies
One color
yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 29, 2008 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
620 people viewed this question
Clive
Clive
old marine
old marine
