Question about Broderbund American Greeting CreataCard Select 7 for PC
American greetings compatible with Vista
I have a new computer with Vista . What kind of american greetingscreatacard gold software should buy, I had creatacard gold 3 which I really enjoyed. Howeverm do not think it is compatible with Vista.
Help Sincerely
5 Suggested Answers
  • 187 Answers
SOURCE: cannot connect to online projects in american
You have to make sure that you allow your program to access the internet. By default, the firewall is set to block all of your programs. To make an exception:
Click the Start button, go to Control Panel, click Security, and then click the Windows Firewall.
In the left pane, click "allow a program through Windows Firewall."
You have to have an adminstrator account, and you may be prompted for the password at this point.
Check box next to the American Greetings, and then click OK.
The other problem you can run into is with active x controls. Allow programs you trust to run this code, or you will not have full use.
I hope this helped. If you have time, please let me know if this addressed your problem by rating the solution before you go. Thanks for using fixya!
Posted on Dec 27, 2009
renosean
  • 492 Answers
SOURCE: American Greetings Creatacard Silver 5.0 will not
Easiest way to try to solve that is to do the following. 1. Go to My Computer and find the cd/dvd drive with the install disk in it. 2. Right click and select explore. 3. Find the installation file 4. Right Click and select properties. 5. Select the compatability tab. 6. Under Compatibility mode check the check box for "Run this program in compatibility mode for" 7. In the drop down menu select windows 98
Select the settings and visual theme settings to match the program specs. You may need to repeat this process after the install to allow windows to open the program. Follow the same steps but look for the program file under c:\ program files.
Posted on Jan 12, 2010
SOURCE: Is there a patch for American Greetings Creatacard
my creatagoldwill not instal on ista??????
Posted on Mar 09, 2010
Morfi717
  • 88 Answers
SOURCE: my creatacard gold 3 american greetings software
As you can see, there is no sollution for that :( you may try right click -> properties -> compatibility tab and run in compatibilty with Windows XP but it doesn't have to work :( Sorry
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=American%20Greetings%20Creatacard%20Platinum&v=Encore&uid=8&pf=2&pi=8&s=Creative%20Audigy%202%20ZS%20Platinum%20Pro&os=32-bit
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
How can I load CreataCard Gold 2 on windows 7
I have American Greetings Creata Card Gold, which my computer states that it is not compatible with my program, is there an updated program?
Aug 08, 2011 | Broderbund American Greetings Creatacard...
Hi - Where can I purchase a new Creatacard 8 Gold New. Thankyou. Gloria
You can get it on amazon http://www.amazon.com/American-Greetings-Creatacard-Gold-8/dp/B00009APG9 If you wish to purchase it locally I'd try a store that sells software like Best Buy or even walmart might have it.
Mar 15, 2011 | Broderbund American Greetings Creatacard...
Are there Vista drivers for American Greetings Creata Card 4?
American Greetings Creata Card 4 is a software for PC with Platform: Windows 98 / 2000 / NT / 95.
You do not need drivers to install any software on a PC.
If you are trying to install the above software to your Vista OS, it is not compatible. If you are looking for a patch for Vista, there isn't any from the developer Broderbund because the version is replaced with newer versions.
Hope it helps.
Nov 14, 2010 | Broderbund American Greetings Creatacard...
Cannot get the american greetinsg creatacard gold 3 to work on my new computer
Most probably your software is not compatible to your operating system(OS).
You can check if your software is compatible with your OS @ http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Hope it helps.
Aug 18, 2010 | Broderbund American Greeting CreataCard...
I bought a new hp touchsmart computer, and i get
If you using operative system above Windows xp, it is not compatible. Se here :
http://www.amazon.com/American-Greetings-Spiritual-Expressions-Jewel/dp/B00006IS7Q
They write compatible with : Windows Me / XP / 98 / 2000
you can try to upgrade your software to a newer version, try to ask the software provider, normally it is writed in the field About under the Help menu.
Hope that helps
Have a nice time over there
Please rate my answer
Nov 28, 2009 | Broderbund American Greetings Spiritual...
Open Questions:
See all Broderbund American Greeting CreataCard Select 7 Questions
Broderbund American Greeting CreataCard Select 7 for PC Logo
283 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
