Question about Micro Innovations CPQ321MM Computer Speakers
Cpq321mm microinv. desk top speaker system . I need to know what voltage the power supply is as i have put mine in a box of 35 different ones
    Problem Solver:
  • 5 Answers
AC Adaptor Model RGA57122000 Input 120 VAC, output 12 VAC 2000mA. I have this very set and just now took the info off the unit.
Posted on Dec 31, 2008
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
When charging lap top it says plugged in not charging.
Power supplies can go bad as well as battery. You need an ohm meter to check the voltage on your charger. You didn't mention what model of laptop you have. Then can be different voltages but there is generally a label on the box the cable comes out. It will show in inside and outside ring. One will be labeled positive (+) or one negative (-). If you have a voltage meter you can put the black on negative and the red lead on positive and read if there is a voltage output.
Feb 06, 2015 | Computers & Internet
Samsung main power supply desk top monitorS20A350BS desk top
you must measure the output from your power supply see the diagram attached in the box. If some Voltage like +5vdc is missing you must replace the power supply. If the Monitor NOT turn ON try to test in another computer more easy. or go to the repair shop.Use the bottoms from the monitor and execute from the MENU make test.
God bless you
Jul 27, 2013 | Samsung Computers & Internet
I cant install them?
The CA-2016 desktop 2-piece system it is a USB powered amplifier that draws the power through a USB cable. No batteries or AC power source/wires are required which leaves the desk top clean. The speaker system is magnetically shielded and has a LED power indicator. This being said setup the speakers plug in the USB cable, notice if the LED power indictor light is on. Adjust volume control on speakers and on your computer ( make sure your not muted ). PC's have a lot of different media players that can and will effect the volume control so if one or more of those items are adjusted to low volume or muted, there will be little to no output to your speakers.
Dec 05, 2010 | Cyber Acoustics CA-2016 Computer Speakers
I bought my speakers in the states, but pluged them in over here in Korea. I know the voltage is different over here. Now, when i plug the speakers in, nothing happens. How can I fix this matter without...
the power supply from the state side has two ratings looks something like
input
120V ac
output
XV dc XXX mA
that out put line is what your looking for you can purchase a universal adapter locally as long as its able supply the Voltage out from the state side wall adapter.
Jun 10, 2010 | Philips (DBMMS171) Computer Speakers
We use our projector for training purposes and the sound is not loud enough. Is there a speaker attachment that can be purchased for the x1a?
almost and desk top speaker system can be used, this includes the power supply for the speaker system needing to be used.
May 18, 2010 | InFocus X1A Multimedia Projector
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Apr 23, 2010 | Packard Bell (190169) Power Supply
I have Bose® Companion® 2 Series I computer speakers. I need to replace the adapater and want to know if speakers accept +ve or -ve polarity voltage. Thanks!
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Feb 08, 2010 | Bose Companion 3 Computer Speakers
Desk top
No Power, No POST, No Video
1. STEP: Ensure Correct Power Button Is Used and Is Not Sticking or Broken. If the power button remains depressed during the power-on attempt, the computer immediately powers off, mimicking a "no power" symptom. Ensure the button is not being held down too long or binding against the bezel or chassis. If necessary, remove the front cover to press the button directly.
2. or else...STEP: Check the Power Button LED on the Front of the Computer (on Blinking yellow)
Initial state of LED at power up.
Indicates system has power, but the POWER_GOOD signal is not yet active.
If the hard drive LED is off, it is probable that the power supply needs to be replaced.
If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed. Look at the diagnostic LEDs for further information. or lese..
3. STEP: Restart the Computer Using the Power Button.Press and hold the power button down until the computer powers off. This should not require more than 10 - 15 seconds.Press the power button to turn on the computer.
4. STEP: Verify the Power Supply Voltage Selector Is Correct for the Region. Verify the setting for the power supply:
*Unplug the power cable from the back of the system. *Press and hold the power button for at least 5 seconds to discharge remaining power.*Inspect the voltage selector setting on the back of the machine (Figure 1). Ensure that the voltage select is set in the correct position for the region the in which the system is operating: For Europe and Asia, the voltage setting should be 230V.In North America, Mexico, parts of Central and South America, and parts of the Caribbean, the voltage setting should be 115V.*Plug the power cord back into the back of the system.*Turn on the power.
STEP: Try a Different Known-Good Wall Outlet.
STEP: Remove All External Devices. Turn the system off.
Unplug everything from the front and back of the system except for the power cord or AC adapter, including: keyboard mouse monitor speakers printers scanners USB devices handheld PDAs external Zip or CD-R drives joysticks/game pads, etc
Attempt to turn the system on.
Blinking Amber/yellow: Initial state of LED at power up.
Apr 05, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Micro Innovations CPQ321MM Computer Speakers Logo
217 people viewed this question
Top Micro Innovations Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Micro Innovations Audio Player and Recorder Expert? Answer questions, earn points and help others
