Question about Kenmore 73952 Gas Dryer
My Kenmore gas dryer wont heat up.
It spins but, no heat. Could it be a pilot light?
  •  Sherman
    Sherman May 11, 2010
    does the ignitor glow when you turn on the dryer
  • Kenmore Master
  • 8,220 Answers
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor READMORE
Posted on Dec 31, 2008
  • 94 Answers
SOURCE: kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
SOURCE: Kenmore 70 Series
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
Posted on Oct 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Gas dryer Model# 11070202990 will not heat
The number one problema with a gas dryer is usually those intermittant solenoids mounted on the gas valve. If you have no igniton then the first thing I would look for is a blown duct fuse. Mounted on the back side of the dryer on the filter housing near the blower it looks like this:
52f69e9.jpgMore wisdom HERE
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: dryer will not heat
The answer is no, you do not have a pilot light. What you have is an electronic ignition which is faulty. Call in a repairman and you will be back up and running in no time.
Posted on May 17, 2009
jsrock516
  • 5911 Answers
SOURCE: my dryer spins but there is no heat coming out. Is
Most modern appliances (especially gas dryers) do not have a pilot. These applainces use a pilot-less burner assembly that has an electric igniter. It is designed this way to prevent free-flowing gas from filling up the appliance cabinet without ignition. Such a condition could cause an explosion. The way the ignition system in most of today’s appliances work is like this:
1. Press the start button.
2. The igniter on the burner assembly begins to glow.
3. Once the igniter reaches the required current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
If you are having problems with ignition, it may be something as simple as a bad igniter. Just because an igniter glows, does not necessarily mean it is good. They do become weak with age and if they do not draw the required current potential, they will not allow the gas safety valve to open. There are two basic types of igniters:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
If you have questions, or require additional assistance, please post back with a brand name and model number, so that I may be able to assist you better. I hope you find this information helpful.
Posted on Aug 26, 2009
Light pilot light on kenmore 80 series gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Kenmore Dryers
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Dryer heats up then pilot lght turns off, dryer
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Drum rotates but does not give off heat
If the pilot will not light then there is an obstruction between the gas line and the pilot. Most times there is a particle that sticks in the pilot. The pilot needs to be disassembled to clear the blockage.
Usually the the pilot is a simple construction and one of the parts has a tiny hole that easily gets clogged. Obviously this needs cleaned.
If the problem persists, the must be a problem further up. check any elements in between. You could try to blow air through the system with various parts disconnected to identify the obstruction.
May 18, 2009 | Kenmore Dryers
Dryer will not heat
May 17, 2009 | Kenmore 74992 Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Kenmore 73952 Gas Dryer Logo
108 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
