Question about Gigabyte GA-8IDX3 Motherboard
How reconnect my Gigabyte GA-8IDX3, please Help me....
I have disconnected my motherboard Gigabyte GA-8IDX3 from my pc to install in a new case, and I've forgotten how to replace all the connectors in this, the chipset, the led pins, and others, please if you can help me...I have already the manual, but it is not indicated for the power connector, led connector, etc, etc. I feel me lost, Thanks by your help....
  • muntuumo Mar 11, 2008
    I do not have the manual to connect my led connection.
    President:
  • 2,961 Answers
If you download this manual, the instructions are on page 23 labeled G:F_panel http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8idx_e_1006.pdf
Posted on Apr 29, 2007
Hello! I have got GA-7VAX rev1.1 motherboard, but the embedded (internal) front speaker is disconnected. Can you, please, tell / show me the right pins to connect speaker to ?
Go to the Gigabyte website
http://www.gigabyte.com/support-downloads/download-center.aspx
and enter the motherboard number GA-7VAX
and you can download the manual which shows what the pins are.
Apr 25, 2011 | Gigabyte GA-7VAX Motherboard
Installed new motherboard (Gigabyte GA-G41M-ES2L), I cannot figure out where to plug the blue & white wire coming from the main power button on the front of the computer on the motherboard. Please...
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Dec 30, 2010 | Gigabyte GA-G41M-ES2L Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Ga-7zm motherboard. I have no video from agp...no beeps I was getting 8 beeps....that was memory problem
Many times during repairs or installation of a main program, the feed to the MB gets disconnected and you lose your video and some times audio. Please install the video driver again. You may have lost both video and audio and for this you don't hear beeps. In this case you will need to install both video and audio. Make sure that your drivers are not "zipped". That is what I do to my computers, also. CONSTANTIN (arzconst)
Jul 10, 2009 | Gigabyte GA-7ZM Motherboard
Gigabyte ga-8ld533 mother board problem
i have a problem with my mother bord 8ld533.my head phone is not working properly also its working with a small sound,alredy a have installed my sound driver..can you help me please...
Oct 31, 2008 | Gigabyte GA-8LD533 Motherboard
USB drive is not working - Drivers are installed.
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Sep 03, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
SOUND CARD
Go to following link:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
Select your motherboard model & install the neccessary drivers. Hope this helps.
Please do not forget to rank this solution...
Aug 06, 2008 | Gigabyte GA-945GZM-S2 Motherboard
Gigabyte Slot 1 GA-6BXC Start Up UnStable
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
May 27, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Gigabyte GA-8IDX3 Motherboard Logo
103 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
