Question about Yamaha RX-V1700 Receiver
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
I just connected a Sony BDS350 blue-ray player via a Monster 800 8' HDMI cable to a Yamaha RX-V1700 receiver as part of a new home theater system. The Yamaha RX-V1700 is in turn connected to a Sony Bravia 37" XBR6 LCD via a second Monster 800 8' HDMI cable. The Sony products were purchased in Nov '08, the Yamaha is older by at least one year although never used prior to this event.
Follwoing setup, I ran a couple of Blue-ray movies and in all cases, somewhere during the movie (typically 45-60 mins after start), the TV screen goes blank and the audio stops momentarily. A few seconds later, the system resumes. Once this process begins, it repeats the "blackouts" about every 10 mins, although at a somewhat random interval. During one of these blackout events, I switched the audio source to the receiver's "tuner" and audio plaback was immediate.
The Yamaha receiver and Sib/Cub 5.1 speakers were installed and operated for only one day. However, the Yamaha's audio automatic setup feature was run and the results indicated no wiring or speaker problems. Further, playback of other sources (e.g., FM radio) seems to be fine.
The Sony TV and Sony Blue-ray player, prior to their integration with the Yamaha Receiver as part of the home thearer system, were operating in a stand-alone configuration for the past three months and no problems were observed during this period.
Any idea why I'm having movie playback "blackouts?" I suspect a compatibility issue between the Sony BDPS350 and the Yamaha RX-V1700 but why does it wait so long to begin?
I don't think there's a heat issue as all components are in unobstructed area at 68-70 F room temperatures. Too, why would other audio sourcces continue to work?
  • Anonymous Feb 10, 2009
    my rx-v1700 has a similar problem. while waching cable through a box the sound will go off during a change to or from a commercial, until i pause or change the channel. the hdmi will not play video and does not change with multiple attempts to troubleshoot. i have had to use the red, blue, green cables to get video to the tv.
    Problem Solver:
  • 7 Answers
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Posted on Jul 07, 2009
Try firmware fix. Go to yamaha site and download and run on cd connected to RXv1700
Posted on Sep 11, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
Suggestions to hook up HDMI cables
I'd suggest running all HDMI.  I believe your receiver has 2 HDMI in's and one out.  Run the out to your TV and run the components to the inputs on the receiver.  This way the receiver will control the video.  Works good for me!  Hope this helps!
Dec 27, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V1700 Receiver Logo
563 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
