FM plays extremely low volume
All FM functions work perfectly, though you have to turn up the volume to MAX to barely here anything.
  • sotirin Dec 29, 2008
    Yea, everything works perfect on this receiver but the FM problem above. As if the unit had a -90db mute switch for the FM only.
    Thanks!
  • sotirin Dec 30, 2008
    Hi Dan,
    Thanks for the info, much appreciated.
    The unit is: Pioneer SX-3700.
    You guys are great!!!
    Thank You,
    Mitch
  • 4,234 Answers
Two things to check:
1) Verify that the tape monitor switch is not on. If it is on you hearing crosstalk only.
2) Verify that the unit has a jumper wire from pre-amp out to Amp-in, if your unit has it.
If neither of the above are the problem, please post the make and model and further details will be provided.
Thanks,
Dan
Posted on Dec 29, 2008
  • ABRsvcs Dec 29, 2008
    There is ususally a "pre-amp" section for the tuner that may be defective. This is before the switching IC/system so it won't effect any other selection. Please send along the make and model so I can give you the part that is likely to be at fault here.
    Thanks,
    Dan
I have an audiosonic KM3608N DVD player and an LG TV. I have perfect sound when watching TV but seemed to have pressed something on either TV or DVD remote that has caused the DVD player to play at...
Please go to audio output menu on your DVD screen check them and when on the DVD channel check your audio input menu. You could have turned on the volume limit on your DVD settings menu
Nov 02, 2017 | Car Audio & Video
I have a Onkya TX 910 receiver that has recently started malfunctioning. It is currently hooked up to one speaker and it is putting out very little sound (as if it is on a low output but it is turned all...
Turn the volume down to about 1/4. If you can't hear it there it isn't going to suddenly appear at higher volumes. Never troubleshoot anything with the volume at or near maximum.
Look for a mispositioned Mute or tape Monitor control.
Jan 18, 2011 | Onkyo Audio Players & Recorders
2004 NISSAN SENTRA . THE VOLUME OF THE RADIO STOPPED WORKING. THE KNOB WORKS, THE BUTTONS FOR DIFFERENT RADIO STATIONS WORK. THERE IS JUST NO VOLUME.
same this happned to me in my 2006 sentra. the volume for the radio is gone. i can tune, its just barely audible/ quiet. weirdly though it sounds perfect when playing CDs. i almost thought maybe it got switched in to mute mode or something. did you figure out your problem?
Jun 17, 2010 | 2002 Nissan Sentra
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
Can hear no sound during any form of playback
mybe she turnd off the sound try to turn it back up, on the side there are these buttons that go up and down, click on the one that goes up.. hope this helps
May 27, 2009 | Samsung Eternity Cell Phone
Can barely hear sound even though volume is max
thebuzzer of your phone is defected, replace itand replace also the earpiece
Apr 09, 2009 | Samsung Eternity Cell Phone
Low volume
You can use a FM modulator and hear it fine through your radio, but then you have the problem of no radio to listen to.........Im lost too.
Jun 23, 2008 | Sanyo NVM-4050 GPS Receiver
No sound
1. check if the amp is in PROTECTION mode (might be a bad speaker or shorted output)
2. check the 'MUTE' switch
3. try to use the FM/AM mode to isolate an input source. If there is sound then check input source.
4. ...still no sound have a techinician check it.
Apr 15, 2008 | Denon AVR-2400 Receiver
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
73 people viewed this question
 Grubhead
Grubhead
