Question about Philips SA5125/37 MP3 Player
Philips SA 5125 MP3 Player turns off and on when connected to PC
Hi,Tried to connect this MP3 player that I got for xmas,but it just keeps turning off and on,so can never have a longer enough connection to the PC to transfer any music.Any Ideas??
  • 496 Answers
Try doing a reset on it flip it over and near the bottem right corner of the player theres a pinhole put a paperclip or something stiff and small in the hole and hold it for about 15 secons and see if that helps or you can put it into recovery mode by holding the volume up key while connecting it to your pc
Posted on Sep 29, 2009
MP3 player won't turn on.
Well its a software problem so try connecting it to your pc and format it....i think sa kinda virus affected your mp3 player
May 30, 2010 | Philips SA3025/37 Flash MP3 Player
SA 5125/37 MP3....Displays music...but no sound
check the output jack on the MP3 player...usually both channels does not stop functioning at the same time. Might be a loosed solder inside.
Aug 24, 2009 | Philips SA5125/37 MP3 Player
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Philips SA 5125/37 MP3 Player
check out philips.com under the support section and then under mp3 players there should be some links there and the software for it
Jan 06, 2009 | Philips SA5125/37 MP3 Player
Need help
Uninstall all Philips software.
Then, re-Install the CD that came with player.
Then plug in the mp3 player to pc.
Try again.
If no go, try every usb port on pc.
If still no go, then:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 30, 2008 | Philips GoGear HDD1830 MP3 Player
Computer not detecting
In order to force the computer to reocgnize the device so that you can run the Philips Device Manager and repair your player, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | Philips GoGear HDD075/17 MP3 Player
Please help
Try to hold down the power button while pushing the volume button up at the same time. This resets the device. It should help
Jun 02, 2008 | Philips GoGear HDD6330 MP3 Player
Philip's Go Gear 30 GB
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
You must do a firmware upgrade to resolve this issue.
Open Philips Device Manager (Go to Start--> all Programs--> Philips...), and click on Update tab
OR
You can get it from www.usasupport.philips.com
It will delete all songs off your player, so be forewarned
Enter your model number on the website, click the link on next page that says SA 5125/37 w/o a "b" on the end
Click on Software and drivers tab
Click on firmware upgrade software - instructions enclosed
-Tha Mp3 Doctor
Feb 08, 2008 | Philips GoGear HDD6330 MP3 Player
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
Philips SA5125/37 MP3 Player Logo
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
