Reset hi i refilled up engine oil two weeks ago. but now, check engineroom ramp is turning on. so i wanna try to reset my car. can you tell me where is reset button?
  • Anonymous Jan 02, 2009
    dodge neon 2003 stx
  • compuwayne May 11, 2010
    What type of vehicle do you have?
  • 42 Answers
Remove negative battery cable for 1 hour. Reinstall. This will reset the computer along with the check engine light.
Posted on Jan 15, 2009
Was getting off exit ramp van stopped suddenly no warning engine wont kickover 178,000. miles just had oil change 2 days ago
check that the cam shaft is turning ( broken timing belt/chain)
run fault codes to check for cam/crank position sensor
check immobiliser operation
Mar 06, 2015 | 2008 Chrysler Town & Country
Check engine light and oil light reset.
the oil light can be from a bad oil sending unit or a faulty oil pump in the engine, i would have the pressure tested ASAP at a shop.
once the issue causing the codes that turn on the check engine light are fixed it should be reset by the mechanic that did the work.
Oct 11, 2012 | Chrysler Cars & Trucks
Hi there !! my car now haw 65.000 milles i'd change oil 3 weeks ago , but now the light comes on , what could it be ??? could you please tell me what happen , 'cause i want to sell the car soon...
WHAT LIGHT COME ON.IF LOW OIL LIGHT COMES ON CHECK OIL DIP STICK.OIL LEVEL SHOULD BE ON THE FULL MARK.IF OIL LIGHT COME ON CHECK OIL DRAIN PLUG AND OIL FILTER EITHER ONE COULD BE LOOSE LEAKING OIL.IF OIL LIGHT NOT COMING ON AND YOU SEE SERVICE ENGINE LIGHT THAT CAR TO ANY AUTO PARTS STORES.THEY WILL CODE SCAN CAR FREE AND TELL YOU WHAT TROUBLE CODE YOU ARE GETTING.
Sep 11, 2011 | 2002 Suzuki Grand Vitara
Want to change oil
get 5w-30 (4-6 quarts depending), and oil filter for your vehicle. get front end of car up on ramps or stands, find and take out the plug (bolt) for the oil - this is under the engine, usually the lowest bolt on there - it is located in the oil pan. The oil will drain - put catchcan underneath first. Then unscrew the filter (oil will also come out here). Replace old filter with the new one (rub a little oil on the new gasket) - tighten this hand tight (should be about 1 full turn once gasket contact is made). Screw the plug back in and tighten. Refill with oil. Turn car on - check for leaks. Turn car off, check oil level - add as necessary. (no not overfill)
Feb 03, 2011 | Smart fortwo Cars & Trucks
I have a 2008 Chevy Impala and I just had an oil change done about 3 weeks ago. Just recently the warning light turned on saying "please change oil engine soon? I checked the oil and it is still full with...
YOU HAVE TO RESET OIL LIGHT.ITS DISPLAYED ON THE DRIVER SIDE INFORMATION CENTER.IT A CHECK MARK LOOKING SYMBOL..YOU PRESS HOLD RESET BUTTON FOR 5 SECONDS.
Jan 23, 2010 | 2008 Chevrolet Impala
Check engine light came on this morning, mazda 3 09', it has 14,500 miles, i just got an oil change at the dealership a few days ago, also i think the gas cap was a little bit loose i noticed the last time...
I would take it back to the dealer and tell them the check engine light came on not long after oil change. Have them run the code on their dime...it's a reasonable request!
A loose gas cap will defintely trigger the engine light, but in most cases, it will reset itself within one week. Some cars don't have a reset which forces you to have a mechanic reset it for you.
Aug 12, 2009 | Mazda MAZDA3 Cars & Trucks
Oil light flashing, last oil change 7 wks ago
I belive they didn't reset the oil light timer. I belive the sequence is 1. key on (not acc with engine off)
2. step on the brake pedal 5 times within 10 seconds. 3. key off. 4. start car. 5. check if the light went out. you may have to try it a few times to get it.
Jun 25, 2009 | 2003 Pontiac Grand Am
Hi, can you tell me how to reset the change engine oil light on my 2002 GMC Sierra 4X4 1500 PU. I changed the oil two weeks ago. Thanks, Gene
with key on engine off depress accel pedal 3 times within 5 secs. You may have to repeat the procedure several times for the reset procedure to complete. dont stomp on the pedal. Slowly depressing seems to work best.
May 08, 2009 | 2002 GMC Sierra 2500HD
Engine light is on.
Your vehicle’s computer system has self-testing capability. When the computer senses that there is a problem with some of the components it stores the correspondent trouble code(s) in its memory and lights up the Check Engine or Service Engine Soon lights to tell you that there is a problem and you should have the car diagnosed and repaired. Not fluid related, but could be a small problem that's easy to fix now. Even a loose gas cap can turn the light on. Have a code scan, that's the starting point.
Dec 16, 2008 | 2002 Isuzu Axiom
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
