Question about HP Pavilion dv8000z Notebook
I have a HP Pavilion dv8000 laptop and purchase a Seagate 80GB 5400/8MB 2.5 Mobile PATA HD to replace the original one. I have reinstalled in exactly the way the original was installed. When I power on the Laptop I get the following message on a black screen: Intel UNDI, PXE-2.0 (build 082) Copyright (c) 1997-2000 Intel Corporation For Realtek RTL8139 (x)/8130/810X PCI fast Ethernet Controller V.2.13 (020326) PXE-EGI: Media Test Failure, Check Cable PXE-MOF: Exiting PXE ROM I also have the Recovery Disc set which I ordered from HP Any help? Thanks, Joe
    Master:
  • 413 Answers
For all of you that are havin problem wit media test type failre, there's a website posted to help deal wit this kind of problem. I have typed in Google media test type failure, and I have gotten two websites with some good explaination to this problem. Here's the two website I have run across www.computerhope.com/issues/ch000706.htm and www.nocrash.com/ncbbs/msgs/3247.shtml. They explain the issue as having to be a problem wit incorrect Bios configuration or a bad hard drive. I'm thinkin this could also be triggerd by incorrect configuration of the jumper. Meaning, the CD-ROM nor the Hard Drive isn't setup. I somehow, found that if u select both to Cable Select on seperate ide cable. It won't trigger this msg. But if you're runnin' it off a single cable. The first have to be set to Master while the last one set to Cable Select.
Posted on Dec 29, 2008
  • 91 Answers
You removed the original harddrive... Did you think that magically the computer would have your operating system on it without the original harddrive in place?
The error is telling you that there is no Operating system, The network card would be the last spot the Bios would check for a bootable link.
Put the old harrdrive back in before you hurt it more and bring the laptop and new drive to a professional to have the upgrade performed properly.
3 Suggested Answers
  • 81 Answers
SOURCE: windows dont come up.
I had this happen to me before with an IBM laptop. I bought a new hard drive, reinstalled a fresh OS, and had no more problems after that. I also went right to ibm website and did all the updates, as well as all the microsoft updates. So my same problem as your ended up being a bad hard drive. maybe check into that?.
Posted on May 30, 2008
  • 707 Answers
SOURCE: no bootable CD in ATAPI
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Posted on Nov 08, 2010
Hp laptop service manual
Try the following websites:
www.retrevo.com/support/HP-DV8000-Laptops-manual/id/608ci675/t/..
www.eserviceinfo.com/downloadsm/61368/HP_Pavilion.html
Jan 10, 2013 | HP Pavilion dv8000 Series Laptop DVD Drive...
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Hp Pavilion dv8000, I have 3 white lines going down my monitor, what is it and how do I fix it
This problem is related to your computers graphics card.
It may need replacing, contact a computer technician in this regard.
Take care!
damnor01
Sep 12, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
Have an HP Pavilion ze4935wm laptop. Want to upgrade to higher GB and RPM. What is the highest I can go with this type of laptop?
This is an older laptop that uses a PATA (sometime called EIDE or ATA-100) drive.
The largest drives commonly available in PATA type for laptops are 320GB, at 5400 RPM.
There are bigger and faster laptop drives, but they will not work with that laptop since the bigger drives require a SATA interface.
PATA drives are more expensive than their SATA equivalents, it might be better to invest your upgrade dollars into a newer laptop.
Apr 17, 2011 | HP Pavilion ze4935wm PC Notebook
Can I replace orig hp ze1115 20GB hd w/60GB hd?
No the bios should be able to read the drive fine. The problem could be with the computer's motherboard. You should check to see if the original drive and new drive is detected in another system. Or you can try accessing them via an external casing / adapter.
May 25, 2010 | HP Pavilion ze1115 Notebook
Where can I buy a lower price HP PAVILION DV8000
It's much better to buy the battery from the manufacturer's website. The transaction is a lot safer and reliable. Take there are two categories of battery the ORIGINAL and REPLACEMENT. Normally the highe mAh capacity has the longer battery life. The price of REPLACEMENT batteries are much lower than the ORIGINAL batteries.
You can view the product on this site:
http://www.shopping.hp.com/webapp/shopping/product_detail.do?product_code=EF419A
Thanks.Cheers!
Apr 21, 2010 | HP Pavilion dv1000 Notebook
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
Will the seagate 80GB PATA HDD be compatible to Dell D420 model
Yes it is compatible.
Could you please rate this fixya.
Thanks
May 04, 2009 | Dell Latitude D420 Notebook
HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Apr 10, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv8000z Notebook Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
