Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Cut styrofoam When you mention remove back wall do you mean inside the freezer or the back of the fridge?
  • 1 more comment
  • John-Pat Mulder
    John-Pat Mulder Jan 01, 2009
    I have removed some of the styrofoam and so far it appears to be working I will keep my fingers crossed thank you for all your help.
  • Anonymous Jan 22, 2009
    i had a technician over yesterday and he cut away the styrofoam as well and figures this should help the water run down and not freeze in the back panel. he says this happens on most of these models
  • Andrew Lauder May 11, 2010
    yes that is correct.
3 Suggested Answers
SOURCE: lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Posted on Jan 30, 2009
  • 142 Answers
SOURCE: i have an lg grl207tvj fridge freezer which is
sounds like it air will get in and over freeze.
Posted on Sep 14, 2009
Water is frozzen in door
The word is that many fridge manufacturers didn't insulate enough in the freezer door. The easiest fix I found for this is get some styrofoam from the walls of a cheap cooler and tape it to the inside of the freezer side door right behind where the water and ice dispenser are located. It works faster if you turn off the fridge for a couple of hours to let the water line thaw first. Then it should remain unfrozen.
Aug 25, 2014 | Hotpoint HSS25GFP Side by Side...
Won't stay cold
The fridge depends on the freezer for cold. Now that winter is coming, the mice are playing. Pull the cover off the tubes in the back and make sure there are absolutely no openings in the back of the freezer. Mice like to travel up the tubes and chew away at the styrofoam where the tubes go into the freezer. Sometimes, they also get into the freezer and block the drain opening. When this happens, the freezer becomes ice-bound and the cold air won't circulate until the ice and dead mouse are removed. To see the drain, you will have to remove the inside walls in your freezer.
Dec 13, 2012 | Amana Refrigerators
Msd2651 wont cool after being unplugged for over a year
Check for mouse damage inside the freezer walls and inside the metal tube cover on the back. Mice LOVE to chew styrofoam, especially when they aren't being disturbed.
Dec 13, 2012 | Maytag MSD2651 HE Side by Side...
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Fridge was left open last night all night long and now it will not work..please help it is not even 1 yr old.......
the air ducts are froze up,if you lost your food you can just unplug it and leave the doors open and let it melt out,or you can unplug it,remove everything out of the freezer,remove the back inside wall of the freezer and melt out all the ice that you see,then look at the right side in the back down at the bottom of the freezer there's an air duct there,melt that out and in the fridge section look to see if you can see any air ducts on the left hand side wall,blow hot air into any of the air ducts that you see,just watch out,don't keep the heat blowing on the ducts for to long,you can damage the inside of the ducts,there's styrofoam in them and the heat can damage it,good luck it might be best to just let it melt out on it's own
May 11, 2011 | Frigidaire FSC23F7D Side by Side...
Freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Jun 06, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have a new fridge but it won't cool in the bottom section. There is stiroform in back of freezer. Was it supposed to be removed? WW
Good day,
You should really call the store where you purchased it, but. If there is a block of styrofoam inside the freezer compartment, it should definitely be removed. It may be blocking some of the air vents.
Jan 05, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
54 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
