Question about Kenmore 15864/15862 Top Load Washer
Sears 90 Series Washing Machined throws ground fault during spin.
I have a Sears 90 series WM that "sometimes" throws my ground fault during spin cycles. Sometimes it doesn't happen for a couple of weeks then it will happen during every spin cycle. I have torn the machine down and am going to replace the transmission coupling because it looked like it needed it but I can't find the cause of the tripping of the ground fault. It makes sense that water is leaking somewhere and getting on electrical but I can't see any water damage or corrosion. Please help.
Phil
Pvatki, I am a licensed electrician and the NEC (national electrical code) does not require a clothes washer to be on a ground fault circuit interrupter. Replacing your gfci with a standard duplex receptacle will fix the problem you are having.
Posted on Dec 31, 2008
Series 700 and won't spin. Has code d r n
Throw it in the trash. There are too many consumer complaints about the sears 700 washers and dryers. Quit shopping at sears. Kmart owns them, so now it's bad to worse.
Apr 02, 2016 | Kenmore Washing Machines
Bosch nexxt 300 is extremely loud and moves during spin cycle.
machine not balanced on ground, check if it rocks without lifting it off ground, if it does not balanced, adjust the ground nuts or bearings are gone
Jul 19, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
I have a sears series 90 top load washer. The
The best way to unclog your dispenser is to pour hot water into it.
Aug 15, 2009 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
178 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
