Question about Bosch Exxcel WFO 2264 Front Load Washer
Key sign on screen
When I try to turn the machine on and select a cycle, it beeps as if has just finished and there is a key sign on the screen. It won't respond to hitting start and so won't work at all.
The last wash finished fine and there has been no problem with it all day ?
Thanks in advance,
Will
  • 1 more comment
  • william_j_sm Dec 29, 2008
    nothing in the drum and the filter looks clean, what does the key sign mean, the door is open ?
    tried unplugging for 3 minutes, that hasn't worked.
    You da man! Thanks.
    Master:
  • 479 Answers
Unplug the machine from the main power out let for a while and replug it after   sometime.this will reset and solve the problem.
Posted on Dec 29, 2008
    President:
  • 2,110 Answers
Is there any water in the drum? clean out the pump filter
  • Sibananda Jena
    Sibananda Jena Dec 29, 2008
    you need to turn the dial to 30 degrees & then keep your finger on the start button for 10 seconds & it should go off.
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
How do i log on to the safeboot mobile data security on my pc
Answer: To get into Safe Mode with Networking: 1.Log out and reboot your machine. 2.When the machine starts the reboot sequence, press the F8 key repeatedly. 3.Select Safe Mode with Networking from the resulting menu. 4.Login. If malware has changed your password, try logging in as Administrator. By default, Administrator has no password. 5.The machine will continue booting, but the Windows desktop will look different. 6.When you're finished doing what you need to do, log out and reboot back into normal mode. Hope that helps.
Mar 23, 2011 | Computers & Internet
PSAFGU-058002 Satellite A215-S6804 15.4" Notebook PC Notebook: My Toshiba is now showing a black screen!!!I had f...
Try restarting with F8 key pressed to bring up the boot up screen, select Safe mode. See what is the problem. If required re install Read more at www.fixpcfreeze.com
May 06, 2010 | Toshiba PSAFGU-058002 Notebook
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Won't finish spin/drain cycle. was beeping and
long drain? remove lower cover on front..3 screws across bottom edge. there is a screw-on cover to a clean out. has a screen in there and may be clogged. prepare for a lot of water..u might lean it back against the wall to limit the mess. clean out is white plastic right up front.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
My washer won't turn on. It just beeps when i
Hi, this is a main control panel issue. here is a procedure you can preform to gain control back.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START.
If the problem persist, you will have to have the control panel repaired by the service tech.
Mar 07, 2009 | Whirlpool WFW9400S
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
