Question about Canon Powershot SD450 / IXUS 55 Digital Camera
My Powershot 450sd camera is not reading 4GB SDHC
HI,
I bought a 4GB SD HC memory and get a "Memory Error" in my camera. I can use it in my BB device.
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Posted on Feb 09, 2009
2 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: My Powershot 450sd camera is not reading 4GB SDHC
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Posted on Dec 29, 2008
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
Oct 24, 2009 | Canon Cameras
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
377 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
