I have a Grundig ST 55-800 NIC/TOP TV and a Philips Video vr 151. All cabels are connected and the whole thing is not working and yes de normal channels do work but not the videotapes. - The TV works normal; - The TV works normal with the DVD player - The VCR should be allright, although I haven't used it in three years; - The videotapes should be all right. I tried several tapes without getting an image.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If I understand your concern right, it is that you can not watch the videotapes when played on the Philips VR151. Everything else works as expected (Cable TV & DVD). It would all depend on how the Philips VR151 is connected to your Grundig ST 55-800 NIC/TOP TV. Possible connections are:
  • SCART - set the source selector of the Grundig ST 55-800 NIC/TOP TV to SCART;
  • RF/coaxial cable - the TV must be tuned to UHF regular broadcast channel and not Cable. The default is Channel 36 UHF. there is also an adjustment at the rear of the Philips VR151 to fine tune
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
  • Louie  Role
    Louie Role Dec 29, 2008
    and then of course, a few other requirements since it has not been used for some time:
    • clean the video head with a VHS head cleaner;
    • exercise the VHS tapes using a rewinder/forwarder.
    Cheers.
    Novelist:
  • 163 Answers
Your VCR needs Head cleaing, because as you says that you are not using the VCR...
    Master:
  • 479 Answers
May be the lens or assembly that spins has a problem in vcr and needs to be checked.
Hello, I need the code for a telivision GRUNDIG ST
These are the codes to check with Grundig.
1141 1427 1154
1144 1125 1035
1450 1491 1148
If you wish to get more, http://electrohelponline.blogspot.com/
Aug 25, 2013 | Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I've got a LG 42 inch HDTV model GP-DVB-EU When I
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
Nov 28, 2010 | LG 42LC2D 42 in. LCD HDTV
De icing the freezer in a Samsung SW 2630WW
Take all of the shelves out of the freezer side. Take to Philips screws for backing and 4 philips screws from vent cover just above cover. unplug, Use a hair blow dryer and melt it. Put it back together and there you go. Whole operation from start to finish is about 15 minutes.
May 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
Can you plug a DVD player into a Grundig P37 - 1010(B)?
Yes, connection via Scart outlet at back of TV set. Just connected mine today, works perfectly.
Feb 22, 2010 | Grundig GF70-600 TV
Kenwwod VR-615 - display disappears
Its becuase it is dirty inside, Unplug it. Take the case off of it. Get sum compressed air from a computer store or Walmart. Like 10 dollars. And just blow the whole thing out with that canned air. do it ever 3 months.. It should fix the problem for life!(:
Jan 30, 2010 | Kenwood VR615 Receiver
Neeed my NADY 151 VR repaired. Can somebody do
Take it to a music store that sells and services Nady products.
Oct 18, 2009 | Nady Systems Nady UHF16 Lapel Wireless...
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Televison & Video Logo
Top Televison & Video Experts
