Question about Roadmaster (VR500CSBT)
NO SOUND AFTER INSTALLING VRCD400-SDU
I own a 1994 F-150 Ford Truck, remove the original factory radio, purchased Ford connectors and spiced the wires according to color codes on purchased connector packet and the color codes on connector supplied with the VRCD400-SDU. Radio comes on, display shows stations, reads USB port but no sound; not even a hiss.
Please help and thank you,
ALB
  • jwh77 Jan 04, 2009
    I have the same exact problem, I can even put a CD in and it won't even give me a squeak. I installed the VR500CS-BT unit. I installed it ground up as there was a short in the factory wiring. But all continuity tests check out on the wiring I ran. This is on a 1990 Honda Accord.
  • brotherdaveb Apr 18, 2009
    I'd describe my problem too, but it is the same. Someone has to know something!
    Problem Solver:
I had the same problem and all I did was buy new wires the ones that came with the stereo itself burned up and seased to work. now I paid $6.00 for it at best buy. they look the same colored wires as the ones that came in it.
Posted on Sep 25, 2009
Vrcd400 wiring to factory radio connector in 2003 galant
I got the wrong adapter for my antenna and tried to do that you may be able to get it rigged in there but the reception will be horrible they cost like two dollars just go to a car audio place and tell them you need one
Jan 18, 2014 | Virtual Reality VRCD500-SDU CD Player
VRCD400 SDU I am trying to install this radio in a 2003 Saturn Vue that had a factory am/fm/6disc/cassette radio with the 'advanced' (power amp) audio system. The factory system was stolen. The factory...
I would suggest calling or find online Crutchfield. They have been car stereo experts for many years. They sell harnesses for just about any car allowing you to plug in your stereo directly to the existing harness. I guarantee they will know!
Mar 24, 2010 | Virtual Reality VRCD500-SDU CD Player
Vrcd400 -sdu has diferent connector that my Mazda factory stereo
you can buy a wire harness for your car that has the same wires as your radio does and the allows you to plug the harness directly into the cars wire connector.. This way no cutting of wires in the car are needed. price is around $15
Aug 23, 2009 | Car Audio & Video
VRCD400-SDU in Crown Vic, Light but wont work..??
A Bad Ground Wire on the Stereo will Cause this Problem. Have the Installer Run an Extension Ground Straight to the Battery and it Should be OK. Let me Know. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 29, 2009 | 1994 Ford Crown Victoria
My vrcd400-sdu will not trn on...
i have a vrcd400-sdu the reset reset led it go on and off the radio well not come on
Jan 20, 2009 | Virtual Reality VRCD500-SDU CD Player
I have some doubts about my VRCD400-SDU autoestereo installation, could you please send me an example of how should be connected the stereo wires? Already I have completed the connection but I dont...
Here is a link to the owners manual for your radio, it should have all the information you need in it for wiring it properly.
http://www.roadmasterusa.com/forums/index.php?act=attach&type=post&id=46
Aug 21, 2008 | Audio Players & Recorders
No sound...
Hi XX,
Let's try the easy ones first:
1. try to do a reset of the unit;
2. check that all the speaker wirings are:
2.1 connected properly following the wiring diagram;
2.2 not bare/exposed and touching any metal part/chassis;
3. verify that the MUTE is not enabled;
4. try all signal sources: AM/FM, CD, SD Card, USB, AUX;
5. verify that the SEL is set to SUB OFF;
6. replace the CR-2025 Lithium battery of the remote.
If your concern has not been corrected after completion of the above procedures, you may need to:
a. open the unit for a loose connection and/or other diagnosis;
b. ask assistance from the manufacturer's Technical Service at 1-800-445-1797;
c. return the unit for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 02, 2008 | Virtual Reality VRCD500-SDU CD Player
Please help me!!
bwqueen-What type of vehicle are you installing it into,cause some vehicles have built in factory amplifiers.The ones with factory amps need a remote turn on to power up the speakers,let me know and I'll try to help you. cooltek Mar,4/08
Mar 02, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Problem installing car stereo
THE FIAT BRAVO HAS A STANDARD ISO CONNECTION WHICH SHOULD PLUG INTO MOST AFTERMARKET STEREOS AND THEREFORE YOU WON'T NEED TO KNOW THE COLOUR CODE, IF THERE ISN'T ANY PLUG ON THE STEREO BUY AN ISO PLUG THEY'RE NOT EXPENSIVE AND CONNECT IT TO THE RADIO AND JUST PLUG IT INTO THE CAR HARNESS, YOU DON'T REALLY WANT TO CUT THE CAR'S WIRING
Dec 05, 2007 | Car Audio & Video
Roadmaster (VR500CSBT) Logo
694 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
