Canon Powershot SD450 / IXUS 55 Digital Camera Logo
Posted on Dec 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Powershot 450sd camera is not reading 4GB SDHC
Hi, I have a Powershot 450sd camera. I bought a 4GB SDHC memory card and put it in. When i turn on the camera i get a "Memory Error". I checked the memory in my BB device and it works.
  • talk2mun Dec 29, 2008
    also...i did try to format it with the Camera but the option is not available.
  • Anonymous Dec 30, 2008
    HI, Thanks. But when i read up on the website about the compatibility for this camera and it should accept SDHC up to 32GB...so i am confused!!
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Dec 29, 2008
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1194612
Points
12483
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
  • CameraR
    CameraR Jan 01, 2009
    You do have an SD450 right? As per the the Canon website and the SD450 user guide, the SD450 camera was only designed for standard SD and MMC cards.
1 Related Answer
Anonymous
  • Posted on Feb 09, 2009
SOURCE: My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
1helpful
Memory card error SDHC Toshiba
I've checked out your Canon Powershot SD550, and this previously written answer definitely applies to you, Wendy:
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
6helpful
2answers
I`ve bought a 4GB memory SDHC memory card to my Canon powershot A 430 camera, and when i put it in my camera - it says memory card error. I tried to unlock it by the small button, but didin`t help. What...
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
1helpful
Hi there. i have a canon ixus 30 camera. i brought a brand new 4gb memory card for it. when i put it in the camera it says 'memory card error'. i read somewhere that formatting it helps but when i tried to...
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Camera won't read memory cards I have tried several different memory cards, the camera display reads "no memory card"
There are several possible causes for memory card errors. Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. Troubleshooting tips for this problem may be found at this link.
1helpful
2answers
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
4helpful
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
5helpful
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
3helpful
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
1helpful
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
