Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
How do I disassemble the dash board ???
I have a 2007 Jeep Wrangler Rubicon 4 doors (sweet!!!). I hooked up the Radar Detector on the plastic trim above the windshield. I want to run a wire (inside the trimmings) to connect to the cigarette lighter wires so I dont have to have the wires hanging on the outside. I assume I need to disassemble the dash, but I have no idea how. Can you help? Or, do you have a better idea? Thank you!!!
  • chanlabs Jun 14, 2008
    I have a 2007 jeep Laredo and lost my wedding ring in the vent of the dash board.  how do I disassemble the dash board to retrive my ring???
    Problem Solver:
  • 10 Answers
1. Run the wire around the windshield frame, down the side of the dash, and across the footwell until it reaches the center console section. 2. Remove the top panel of the dash stack by prying up on the back edge until it pops free. There are two clips in the back corners, and it will roll off toward the front. 3. There are a couple of bolts that hold the front bezel in. Remove them, and then gently pry the rest of the bezel off -- there are 4-6 more clips like the ones from the dash top panel holding it in place. 4. Find the gray wire with the orange stripe running to the lefthand cigarette lighter. This is ignition switched power. Tap the radar detector leads into that wire. This will cause the detector to come on when you turn the ignition on, and off when the ignition is off. 5. Close everything back up. You're done!
Posted on Sep 25, 2009
Jeep brakes broken
Many Wrangler JK's have lift, but few people extend their brake lines. This is particularly important for Rubicon models. The Rubicons are capable of insane wheel travel, by stretching the wheel travel further (lifted?) you could exceed the length of the feeble factory brake lines. Crown manufactures brake line extensions for Wranglers, specifically for lifts.
Mar 13, 2014 | 2007 Jeep Wrangler Unlimited Rubicon 2...
How to replace horn relay on 2007 jeep wrangler
The horn relay is located in the Intergrated Power dist Box, This is a Cherokee, but you get the idea.
Jul 23, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
The small storage compartment in the back of my 2007 2-door jeep wrangler Rubicon is wet, soaked with water. Where is it coming from?
If your Jeep has a soft top -
I have a 2007 Unlimited and has the same problem. My Jeep is a soft top and the water came from the rain and a poor seal of the back window. Part of the problem came from the displacement of the plastic "c" shaped "rear window bar holder" that clips on to the rear on either side of rear window. Ocasionally the clip pops out of place and breaks the seal between the rubber on the window and the rear sides of the Jeep.
Jun 10, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
97 Jeep Wrangler sport- Cranks, will not
Fuel flow. Either simply, a blocked fuel line (debris / filter / fouled gas) or an electronic issue. Ever let this Jeep run bone dry on gas? Hopefully not, as doing so can draw a lot of crud into your fuel lines from the bottom of the tank. Electronically, if part of the Jeep "brain" has gone bad, there may not be any fuel being routed to the engine. This most likely needs a Jeep mechanic to repair.
May 15, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Jeep 2007 Wrangler Unlimited X 4x4 4 Doors
Sounds like a short in the electrical system. Maybe even just a loose ground wire. On the other hand...It could just as easily be a bad ECM (BRAIN)! Warranty still in tact? I hope so. Diagnostic at a certified Jeep shop... Good Luck!
Apr 09, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
I have a 97 Toyota Camry and have had a leak on the drivers side for over a year and can't trace it. I have been told it was the windsheil and replaced it, have replaced under plug, have tore up carpeting...
blocked drain holes at the bottom of the door
missing plastic membrane that seals off the door openings before the trim is put back on door opening seals broken or not sealing properly
Nov 28, 2017 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Blinkers, Wipers and Dome Light Control do not work. 2007 Jeep Wrangler
That's got to be a fuse. Look in your manual under Fuses to see which one needs to be replaced.
Oct 25, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
2007 jeep wrangler sahara with a mopar remote starter just beeps
That's not a remote starter on your key chain, it's a keyless entry for an alarm system.
Nov 17, 2008 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Dosn't turn over
I am Having the same problem with a 2005 wrangler rubicon unlimited and when I step on the brake some dash lights come on including one with a circle slash over a key on the top left of the dash! I called the dealer and they told me to bring it in because the Vallet computer lost its memory code, I think its strange since I do not have an alarm
Earl
Aug 17, 2008 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Car Audio & Video Logo
804 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
