Question about JVC XV-F80 Multi-disc DVD Player
WON'T PLAY BURN DVD'S
MY PLAYER PLAYS EVERYTHING BUT BURNT DVD'S . THIS JUST STARTED RECENTLY, BRFORE IT PLAYED BURNT DVD'S NOW IT JUST READS AND SAYS NO DISC. I TRIED TO RESET IT AND I GET TEST JC J IN THE DISPLAY ON THE UNIT. IT PLAYS PURCHASED DISCS , AND EVERY CD INCLUDING MY BURNS. PLEASE HELP ME !!!!!!!!!!
    Scholar:
  • 125 Answers
There are two main families of DVD's, the minus (DVD-R/RW) and the plus (DVD+R/W). The most popular is the minus and almost all players can access this types. The newer and better DVD (plus) is not as popular like the minus. SOme players will not be able to read the plus. Check the DVD that you used, if it is DVD+R, try to use DVD-R
Posted on May 15, 2007
SOURCE:
Imported videos onto computer, burnt DVD, will not read on Panasonic DVDS player, does it need finalising if so how.?
Depends how old or what model your DVD player is ? When I burn DVD's with my video editing software on my computer,some disks will not play on certain older DVD players, has something to do with video codes that the DVD player has to read? My experience is that my older DVD players will not play burnt DVD's from my computer, but will play in newer DVD players ?
Mar 05, 2015 | JVC GZ Video Cameras
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
I put in a dvd, it starts to read it, and in a couple of seconds it ejects
Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
Jun 27, 2011 | Emerson LD195EM8 19 in. LCD TV
Just bought an ONN dvd player and will not play burnt dvds. It says it will play DVD-R/RW. Any ideas to why it won't?
Burn your dvds in a proper way. If you burn your dvds as data dvd, it may not work on certain dvd players. Try different software or different PC to burn your dvds. Check the region code of your dvd player & the dvds burnt. They should match. You may find some region-free players.
sonsunny
Jun 19, 2011 | Televison & Video
Sony DVP NS575P will not play pc burnt DVD
John~ check formats with dvd player can be found in mannual - then burn dvd to suit mp3 or mp4 would normally work~ you can go to Realplayer.com to get tool to download on pc to this job. also try
Divx .com / utorret.com
or if you can get a Silvercrest dvd player this can also play pc dvd.in may different formats.
Phil
Aug 08, 2009 | Sony DVP-NS575P DVD Player
Doesn't read my DVD's burnt off my mac anymore
r u sure the format for your DVD that u burnt from MAC is same as DVD that usually can play in DVD player?try to compare your burnt ne with ordinary DVD that can play ib your DVD player...if it is not same, then u have to burn it by using the same format as your ordinary DVD..or if it is same, then your DVD player cannot support the type of DVD that u use...for example like DVD-9, most cheapest DVD player cannot recognize the type of DVD that is used eventhough u use original DVD...
May 26, 2009 | LG DR197 DVD Player/HDD Recorder
Video freezes playing burnt dvd from computer on a dvd player
dvd players are finiky things they do not like burnt dvd's at all and some will just lock up computers on the other hand can handel those because burnt dvd's are in a coding format that computers can read much easier than a dvd player your best bet is to just buy the dvd non burned and see if that fixes it. good luck and If you ever need anymore help with electronics questions pleases dont hesitate to ask me at dragon_rage27@att.blackberry.net
thanks and good luck
Jan 08, 2009 | Technical Hifi Televison & Video
My symphonic dvd/vcr piece of **** was playing recently burned dvds no problem. I received a couple burned dvds which i ordered and everytime i try to play them the screen flashes a "disk error"...
it sounds like your dvd player just cant read the data on just those dvd'sdvd players are different sometimes,plus where you got those dvd's could be the problem.also if someone else burnt these dvd's it could be the software settings they were using,but if they were purchased from a dealer i would let them know about it.or you can try just those dvd's in another player.hope this helps.
Dec 05, 2008 | Symphonic Televison & Video
DDVDRW8DB
It may be how you are burning these discs, if you burn it as a data disc you will only be able to read them with a computer dvd drive, if burnt as video it should work on any dvd drive.
Feb 02, 2008 | Digital Research (DDVDRW8DB) DVD±RW...
JVC XV-F80 Multi-disc DVD Player Logo
141 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
