Question about Sony KP-53V75 53" Rear Projection Television
Television won't turn on- no sound- no picture
Hello, I have a Phillips/Magnavox 50" projection tv (Model# 9P5034-C101- Serial # 27474473- Chassis # PTV835). The problem with this tv is it won't turn on -no sound /no picture - only the green light comes on at the control panel on the tv. What can be be problem? Thanks, Ray.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the presence of the green light is indicative that power is reaching the electronics inside, at least the power supply board. It also indicates that the standby +5VDC is present. When you press on the remote to turn ON completely the TV, would there be a clicking sound (relay activated)? Or some other indicator that the rest of the electronics inside are receiving power? If none, offhand it would be suspect of the power supply board is not supplying mains B+, the TV is in Protect Mode,
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
    Master:
  • 479 Answers
In the tv there is a main board that board is the problem.as any of the capacitors or the ic are got loose or blown off and needs replacement to clear rthis problem. thanks.
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
No Picture
I had the same exact problem pulled the chassis ohmed the convergance ics though one read different than the other replaced both put chassis back in set fired right up.Hope this solves your problem!
Feb 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips Magnavox 9P6040-C101-60" Rear Projection Television
You can get a repair kit for the shrinking/expanding on www.magnavoxhelp.com. This is a common problem with this model.
Sep 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sometimes it turns on, sometimes it doesn't,9P5034 C101 PHILIPS
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 18, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips Magnavox Model 7P6031-C101
  • Try www.magnavoxhelp.com - They kits to resolve similiar problems.
Mar 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Projection Model # 9P5034 C101
Yes you will need to discharge any electrical equipment before working. One way of doing this is keep equ. unplugged for sometime or after unplug short hot to ground which will most times cause a spark. You can go to vancebaldwin.com or andrewelectronics.com or any online parts store and get the part number off old IC, yes these are on the convergence module. They are big STK's, also there are resistors that will need to be changed and maybe pico fuses.
Jan 05, 2008 | Philips 9P5034C 50" Rear Projection...
Sony KP-53V75 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
