Question about Minolta Color PagePro L Laser Printer
Error codes I cannot find my book to find the error code for which indicator lights mean what. Can anyone please help with the set of error codes?
  • Alan Berris Aug 18, 2007
    I have found the book now. The guest who submitted his views is obviously very clever; or thinks he is. If anyone would like these codes they are now available.
  • Minolta Master
  • 6,763 Answers
Try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 26, 2015
3 Suggested Answers
SOURCE: Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Posted on Apr 17, 2008
  • 1297 Answers
SOURCE: Minolta Di3510F indicated malfunction error with
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Posted on Aug 07, 2009
Rice cooker error code H04
IS YOUR QUESTION ANSWERED?
BECAUSE AM ALSO FACING THE SAME PROBLEM ON MY ZOJIRUSHI NP-HS10 INDICATING H04
Sep 22, 2012 | Kitchen Appliances - Others
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
How to reset malfunction indicator lamp on honda accord
You need to hook up your diagnostic tool to the connector beneath your steering, read the error code and look for its its meaning in a Honda Error code book.
or
disconnect your battery terminals, allow 10 minutes and then reconnect, that should clear the check light. if the check light comes on again, it implies that the reason for the fault is yet to be cleared.
Sep 14, 2010 | 1999 Honda Accord
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Ihave an old Toshiba tv and a Systemlink 3 romote. I lost the code book, please send me the codes. Thanks
The codes for Toshiba are: 049, 071, 072, 089, 105, 109, 117, 118, 160, 162.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
Good luck and I hope this helps. Thanks for using fixya.
Jan 03, 2010 | Toshiba 27A33 27" TV
I have a red light,it blinks 6 times and a quick 3times.its a philips 42pf9631d . is it something i can fix myself? or can anyone help me who had the same problem?
This is an Error code indicating a problem with the Control Module or power supply. Possibly an overtemp. You NEED your user guide to know what this error code means.
You can download a free maunal online using the key code on the s/n label.
Dec 29, 2009 | Philips 42PF9631D 42 in. Plasma Television
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Error codes
when the power is turned off for a period of 30 mins and then restored does the machine still display this error code as soon as you try and start the machine,o and by the way does the door lock?
May 03, 2007 | Indesit W 123 Front Load Washer
Minolta Color PagePro L Laser Printer Logo
115 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
