Question about Hoover S3639 WindTunnel Bagged Canister Vacuum
Hoover s3639 vacuum...cord does not rewind
The electric cord on my hoover s3639 does not wind back.  Is there an easy way to fix it?  If I have to open the body of the vacuum cleaner to do that, how do I open it?  Where can I see an exposed view of the interior of the s3639.  Please help.
  • 2 more comments
  • kasugl Jan 21, 2009
    oh, me too! same exact problem!
    HELP!
    oh, can someone help both of us open up this unit?
  • Steeler12 Feb 15, 2009
    I also have this problem--any solutions--did you try to open it up and take a look at fixing it yourself?
    Mike-Dublin, oh
  • Don Cobb Feb 27, 2009
    I have the same problem, cord want wind back up at all now, got worse and worse about rewinding. I will fix it or tear it up one, trying to figure out how to take it apart now, HELP GUYS!
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Posted on May 04, 2009
Windup spring has come undone from assembly inside reel. I guess you order another reel assembly, probably cost almost as much as a new S3639.
Posted on Feb 28, 2009
How do I replace cord rewinder on Hoover UH70120?
You should not try this on your own. Take it to an authorized Hoover warranty repair center near you. This is not an easy job and is usually not worth the expense if the machine is out of warranty anyway. If it's within the warranty period, warranty will cover it. My shop is a Hoover warranty center and we have replaced a lot of these.
Dec 17, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
How do I get the cord out a Hoover Wind Tunnel?
Hi there! If the cord is stuck and won't pull out, try gently pulling the cord while pressing the cord rewind button. Hope that helps! If you still need assistance feel free to reach us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Oct 01, 2014 | Hoover Vacuums
My hoover wind tunnel cord is all the way out; will not rewind. Can I fix it myself?
I took off the dust canister and then the 2 Phillips screws on top of the rewinder. I was searching how to get at the rewinder so I took out the HEPA filter and holder. I then pressed down on the rewind leaver and it rewound. I am not sure why but maybe what I removed was putting some pressure on the rewind mechanism or I just had good luck.
Oct 27, 2012 | Hoover UH70120 WindTunnel TSeries Rewind...
Repair manual for Hoover Vacuum
If you would like a repair manual, we can special order one for you for your Hoover S3639. Call us at AAAA TEVA Monday through Saturday from 9am to 6pm MST. Our number here is 303-770-6321.
Jul 18, 2012 | Hoover S3639 WindTunnel Bagged Canister...
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How do you open hoover s3639???????
Take out all the tools out of the tools compartment. The screws are "hiding" under the tools.
Jul 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Power Cord is Jammed
Thanks Joe for finding the location of that fifth screw. I've taken some photos to help out anyone else who might be having this issue.
Its on my blog here.
Jul 06, 2007 | Hoover S1361 Bagged Canister Vacuum
Hoover S3639 WindTunnel Bagged Canister Vacuum Logo
1,923 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
