Question about Minolta Di152 Laser Printer
I had a jam, now not working!
I had a paper jam which I removed, however the jam light is stll lit so I cannot use machine, I cannot see anyother jam, paper came out whote.
Is there a way of resetting machine?
  • sales179 Jan 01, 2009
    sorry suggestion did not work :( but thanks
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    Have you tried unplugging it?
  • 120 Answers
Hi
Just turn of the printer for five minutes and then turn on...
Thank you
Posted on Dec 29, 2008
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
The triangle light is lit on the panel. What does
tooner goes to low or paper stucking any where in paper path..check for both ur problem will be resolved
Jul 30, 2010 | HP LaserJet P2015dn Printer
Paper jamming sign lit up but no jammed paper seen
hi there shuld be paper inside or may be when u removed jamed paper not proper way some pice of paper struck in the sensor thats why paper jamed lit up clear the whole paper path it will solve problem if not there is any path sensor not working good just clean the path sensors
thanks
May 14, 2010 | Toshiba e-Studio163 Copier
I removed a paper jam. red light is still on (not flashing).
There is probably still paper stuck in the paper path, this is very common. What happens if you load it with paper and press the test button?
Feb 08, 2010 | Samsung ML 2010 Laser Printer
Paper jam light will not go off and there is not paper jam in the unit.
Over time paper dust and toner residue can build up around the drum and paper feeder rollers. Open your printer and remove the toner cartridge and Drum unit. Use a soft brush to clean any residue. Replace toner cartridge and drum unit.
A tiny bit of paper can cause the paper jam light to stay lit.
Jan 16, 2010 | Office Equipment & Supplies
Showing paper jam at master disposal NOTHING THERE
Remove the power cable from power source for few minutes. If its a temporary software issue it will get sorted out. Pull out master roll and reinsert it. Check wether you have properly inserted the master disposal tray or not. If these don't work ask for further assistance.
Jul 17, 2009 | Riso RZ220 Duplicator
Will not print after pulling forward a jammed paper
make sure the paper didn't tear and a peace got jammed somewhere in there. then reset the printer.
Feb 09, 2009 | HP LaserJet 1200n Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Minolta Di152 Laser Printer Logo
121 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
