Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
Water is not heating up in holding tank
Water feeds automatically into machine, I have turned the heat button all the way up, but the cofee is luke warm. The 4 extra warmers are heating fine. The model # is worn off, but the front says 1985.
  • mzleema May 11, 2010
    There are 4 extra warmers on my machine
    Novelist:
  • 125 Answers
Hello. It sounds like your main heater is blown, or the hi limit is bad, or a wire is burnt off.You will need to find out your voltage at least to make a guess at the part, it sounds like you have a RL unit.
http://bunnomatic.com/pages/techdocs/manuals/autobrew_warm.html
Look at the RL manuals, and try to tell which one is yours.
Hope this helped, and thank you.
Posted on Mar 23, 2009
The light goes on. I can feel the water is heated. Machine makes a lot of noise, but water doesn't pass from resivoir thru to frother wand or thru coffee filter. I am just running water to te
It needs to be descaled. After that, turn and try to make coffe but without the cofee. Turn on the steamer nozzle at the same time, that will draw the water to the coffee area, in fact try that first.
Dec 09, 2014 | Cuisinart EM-100 1000-Watt 15-Bar Espresso...
The coffee is very weak. Have tried several different coffees but the same with all Brands. Have cleaned the top were the water comes out. Have run several cycles of water through it but coffee still is...
Make sure the 'vacation' switch is turned on. In addition to the warmer switch on the front of the unit, there should be another switch located on the side/rear of the coffee maker. If that is turned off, the water won't be pre-heated, and you end up with luke-warm water going through the coffee during the brew cycle. If that is not the problem, then there is an issue with the tank heating element and the unit will have to be repaired.
Dec 12, 2010 | Bunn NHB Coffee Maker
How to decalcify coffee machine Saeco royal digital
Hi
Your showing a different machine than a Royal and that one is different, but if yours is a Royal, this is how.
Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrow buttons to scroll up until you come to Descale. Press enter button and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Nov 12, 2010 | Saeco Incanto Classic Espresso Machine
Can you give me instructions on how to decalify the coffee machine in this photo as l have the same.Thank you Barbara
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Oct 31, 2010 | Saeco Royal Digital Plus Coffee...
I don't have a manual and need to decalcify my saeco stratos. I know I have to buy a bottle of descaler. What do I do then?
Don't use vinegar or CLR or any chemical used in the bathroom. Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Oct 29, 2010 | Saeco Stratos Coffee Maker, Espresso...
Need to decalsify
Oct 28, 2010 | Saeco Royal Professional Espresso Machine
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
I have an older Bunn-o-matic with 2 extra warmers on each side. The water is supplied automatically to the machine but is not heating up, despite my turning the heat knob all the way up. The warmers are...
Here are some possible causes ,the hi temp cut out ,thermostat, or heating element are bad .a continuity tester can determine whitch one .Also you could have a burnt off wire . The reason the water is still luke warm is a electic warming jacket that bunn put around the water tank to limit the therostat cycles during off peak usage very fixable hope this helps
Dec 29, 2008 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
102 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
