Question about Sony SDM-HS73P 17" LCD Monitor
G board Where did you find this g board thing? I fix loads of Sony 19'' and 17'' , and they have inverter, when they are like this , it is either the inverter, the lamp, or the connector. I think the problem became quite confused here. Thanks.
  • Ginko
    Ginko Dec 30, 2008
    I know, I was the one generating confusion, now everything is clear.
    The inverter had been designed on same board as psu, and that is called G board, not a very bright idea by sony engineers.
    good luck all with the user.
    Brigadier General:
  • 6,966 Answers
Cheers.
Posted on Dec 29, 2008
Sony KDL-46BX420 TV has a black screen with sound.
Inverter board powers the back light leds.
Aug 27, 2017 | Sony Televison & Video
I have a 2009 Sharp Aquos 55 inch HD tv. Will only play for a minute or two then shuts off and starts back up. Will turn on and off indefinitely until I shut it off with my remote. How do I fix it?
This is an indication that the power supply cannot deal with something that is putting a load on it. It could also be the power supply itself. If you want to try and see what it is, take the set apart. But you must be very careful with a screen that big. Inside you will see the power board, the inverter, the t-con board and main and or control boards. The first thing to try is locate the inverter and unplug it from the power board. If the set turns on and remains on then the inverter is bad. If not then the power board is bad.
Jan 29, 2016 | Sharp Televison & Video
Tv fix picture screen went out sound is ok sony bravia lcd digital model kdl-40s2010 help
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 26, 2015 | Sony Televison & Video
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Oct 06, 2010 | Sony VAIO PCG-FRV27 Notebook
Hello!Sony SDM-HS73 power-inverter problem
At this point you may have bad transformers, bad tuning cap, you need to check the frequency of the inverter oscillator to see if both of them are running at the same frequency, the bad one may not be. The Inverter/power supply is not made by SONY, Powernet makes the board. Please see what went wrong with the one I fixed.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
One thing to keep in mind, when the board turn into carbon (blacken), it will conduct. The circuits operate at high voltage and high frequency.
Apr 09, 2010 | Sony SDM-HS73/H (Grey) Monitor
My Sony LCD TV has audio but no video
Seems like your time-control board a.k.a. (LCD BOARD) is defective or the power supply board is not producing working dc voltage too the inverters. In that case the power board would need servicing. It could also be the CCFL lamps but thats very rare. See if the inverters are working by only disconnecting the wire(s) going from the inverter too the lcd-board. If the lights come on after you disconnect the lcd-board from the inverter then you know its the LCD board thats the fault here.
Nov 13, 2009 | Sony Televison & Video
Sony bravia KDL40S2000 standby blink four times
A 4 flash issue means either the back light inverter (power supply) has failed or that one of the fluorescent tubes in the panel has failed. The only way to know for sure is to check the fuses that are on the inverter board. If one or more of the fuses are opne, then it is likely the inverter board is bad. If the fuses all check good, then the panel is at fault. If it is the inverter board, it is a part you could replace yourself; the cost of the board is about $70. If it is the panel, you would probably want to consider replacing the TV, as the repair costs would be over $1000
Dec 10, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV Problems!
This is usually the high voltage on the inverter, balancer or backlight arcing to the chassis or at the connections. One quick fix was to look for a burn spot under the inverter(s). If that's the case, insulate the chassis at the point of the spot with a few layers of electrical tape 600v dialectric strength or better and carefully clip the leads just above the solder joint on the inverter board to widen the arc gap. If the white pink wire connectors arc too long they will charr requiring replacement. Cost varies depending on the problem.
Jul 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
279 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
