Question about Samsung DynaFlat TX-P2775H 27" TV
Samsung 27" Dynaflat that warps image
I have a Samsung 27" tv, whenever there is a bright light in the movie (esp, in the upper left hand corner) The image curves and warps and shakes (mainly in the upper left hand corner)...the one time I didn't buy a warranty and I paid too much for this tv to get rid of it. Thanks!
    Problem Solver:
  • 6 Answers
The problem is into your power supply try to check you b+. it is a low b+
Posted on Jun 25, 2007
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
We left our 40 inch ACER televison on the same channel for a couple of weeks. Now in the upper right hand corner is an image that won't go away. Is there a fix?
Im guessing this is a plasma television. Either replace the panel(very costly) or display a bright white screen on the tv and leave it like that for a several hours.
Dec 28, 2009 | Acer AT3205-DTV 32 in. HD-Ready LCD TV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Bright blue "static"-like color in upper left corner
sounds like the corner is being pressed into the back of the Tv which usually emits a "staticy" look. You may have to pull the edge up somehow before the Tv is ruined
Jul 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
DVD'S will not play..
Sounds like the unit is bad, or set to the wrong Regional Code. Its not easy to set the regional code and it varies by model. You are better off buying a new DVD player given they can be found for under $30.
Aug 28, 2008 | Samsung DynaFlat CXM2785TP 27 in....
Green dot in upper left-hand corner of screen.
you can try demagnetising your tv screen
Jan 13, 2008 | Emerson EWF2004 20" TV
If it's not yet a year old it should have some warranty - take it to the shop.. It's probably the HOT (Horizontal Output Transistor) which have been a problem child in this series all the way back to the TXP2745... But don't even crack the case on this one if it's that new - labor might not be covered but parts might. In any event replacing the HOT is not a difficult or expensive job.
Bill
Nov 15, 2007 | Samsung DynaFlat TX-P2775H 27" TV
TV won't turn on
I have the same problem.
Sep 09, 2007 | Samsung DynaFlat TX-P2764 27" TV
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung DynaFlat TX-P2775H 27" TV Logo
176 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
