Question about ASUS P5ND2-SLI (890552603831) Motherboard
Computer won't shut down
After installing a 2nd hard drive my computer won't power off. It appears to be shutting down, logs off everything and goes to a black screen but the power supply keeps running. Everything else runs fine just won't shut off. My motherboard is a asus P5ND2-SLI motherboard and I'm running XP. The 2nd hard drive is Western Digital. Any help would be greatly appreciated. Thanks!
I read an forum, mboar asus shutten dwon NOT avaible.
Posted on Dec 29, 2008
What's wrong if your computer boots up but when it's time to login in the screen goes black?
Depending on what make and model of computer you are using i would advise pressing and holding the power button until everything shuts down and then power on and keep on pressing the F5 key then a black screen will appear and select Safe Mode and see if you can log in on safe mode failing that i would try doing a start up repair.
Jan 25, 2015 | Computers & Internet
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
Computer heats up and shuts down
I would suggest you open the notebook by yourself and clean it from dust. I had an Acer notebook that shut down very often because it had so much dust inside that it overheated.
Jul 23, 2010 | Acer Computers & Internet
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Toshiba Satellite Goes completley off! Black screen, NO POWER!
Hi Steven, in my experience as a tech support agent, it seems that you're having an issue with your hard drive, sometimes it might also be an overheating issue, to be clear on that, please be sure to check the temperature of the computer when it shuts down, then the first symptom of the issue seems to be the clicking sound which ussually comes from the hard drive's reading head, this might indicate the hard drive is damaged and that it cannot perform as usual. The steps to troubleshoot the issue will be as follows; First please enter the BIOS/ System Setup of the system, by pressing the [Delete] as soon as the computer turns on several times, you will appear in a black or blue enviroment with some information from your computer. Check if the issue will happen there as well. Second, if the computer gets really hot at the point when it shuts down, please ensure that all the fans in the computer are running (you should be able to hear them), And be sure of the temperature when it shuts down, we must know if the computer is too hot to touch, or there is no problem with it. Third step, how long will the computer stay on? Will it always shut down at the same time?
The best solution for this issue would be to replace the hard drive, or defective fans depending on the troubleshooting results, if you're still within your 1 year warranty with Toshiba, you should contact their tech support team to replace the part.
As an aditional step to the troubleshooting you should also try to remove the hard drive, and let the computer on for as long as its necessary, to discard the hard drive from the issue, if it doesn't shut down then the hard drive seems to be the problem.
May 03, 2009 | Toshiba Satellite 1805-S274 Notebook
How to log off
If you log off you only close your user session under windows, not turn off the computer.
If you suspend you turn off almost everything in the laptop like hardwire, cd or dvdrom and most peripherals but the computer stays on the consuming power.
If you hibernate what windows does is to store all in memory in a temporary file in the hard drive and turn off all the computer so when you turn it on again it will be as you last session with all your programs and documents you left open.
And if you turn off the computer it will close all your programs, close windows and turn off all the hardware.
Jan 19, 2009 | Acer Aspire 5100-3357 Notebook
Computer won't power off
The most common reason for this problem is that ACPI (the Advanced Configuration and Power
Interface) isn't enabled. To enable it:
Click Start | Control Panel, select Performance and Maintenance.
Click the Power Options tab.
Select APM - Enable Advanced Power Management Support.
Click OK.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1501 black screen
Post the error codes that are given and I'll be able to tell you what's going on exactly.
Jun 19, 2008 | Computers & Internet
ASUS P5ND2-SLI (890552603831) Motherboard Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
