Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher runs but does not fill with water.
Our PDW7800 dishwasher was working fine until recently, it now runs but no water goes in.
Mine is doing the same thing. Any ideas?
Posted on Dec 29, 2008
Water runs into dishwasher when machine is off and if door is open. Model PDW7800
If the only way to stop the water from coming in is to turn the main valve going to the dishwasher off then you have a bad water valve. replace it.
Aug 06, 2010 | GE 24 in. Profile PDW7800 Built-in...
Flooded my kitchen
fill valve got stuck it will happen if you have hard water it is in the bottom left corner of the washer move it around with your hand
Dec 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher runs through cycle but no water.
make sure water is on ,if water is on and still no water in d/w then check water control valve
Nov 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Hello, our dishwasher has been leaving a film on the dishes and just not cleaning. Anyway to troubleshoot the problem?
if you have a salt gauge inside the machine make sure it is filled to the top/leave machine empty and run two hot washes through the machine putting one [extra] tablet inside the machine both times.it is my oponion that this machine is scaled up.adrian;;
Nov 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Jun 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwaser Fills But Does Not Run
You may have a problem with the spray arm being blocked or the water valve may not be letting a sufficient amount of water through to get the spray arms activated. If the dishwasher is still in warranty schedule service before it runs out. GE customer service number is 800-626-2000 model and serial numbers and purchase dates are helpful. Ask specifically if any kits are available to fix these problems and if GE is willing to make any concession toward this repair. Good Luck.
Dec 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
89 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
