Question about TruTech PLV16190 Television
Converter boxes I have a TruTech portfolio 13 inch TV connected to an in house antennae and need to purchase a converter box. The DTV website list does not list TruTech, what brand converter box should I purchase?
  • jori7us Dec 29, 2008
    never mind I was confused. Converter boxes are universal
    Scholar:
  • 73 Answers
Any brand will do. They dont mention TruTech because it is a OEM brand that Target has had manufactured from many different sources. See here....
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Best regards,
Charles
Posted on Jan 09, 2009
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Not receiving HD channels on Trutech set
yes it does,also use an hdtv antenna with the
converter box.you may need an outside hdtv
antenna to pick up all digital channels.
Jul 17, 2009 | Televison & Video
Since the switch to digital transmission, my antenna no longer works with my Trutech 19 inch TV. What kind of antenna do I need to buy in order to get reception?
to add to what MIKEY-MOORE wrote, OUR government was offering discount ($20 off a $40-$45) coupons on a digital converter box that you can use your original antenna ( I still use my original nineteen and 65 (1965) rabbit ears antenna) to receive the digital signals NOW being transmitted through the air. In order to receive the signals YOU MUST get the converter. GOTO any Radio Shack, Walmart, to acquire the converter box. You will need one for EVERY tv in your house. I have a HDTV (but not digital) and I had to buy 3 boxes.
Jul 17, 2009 | TruTech PM1919BXA1 19 in. LCD TV
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Need adator for DTV converter box.
The converter box needs an antenna, but not the one built into the TV. In fact, you should get an antenna designed for the new DTV broadcasts to get the best reception. There are a number of styles and they start at under $10.
To connect the converter box to the TV, you have a couple of options. You can use the channel 3 or 4 output from the box and connect the cable to the TV external antenna jack with the appropriate adapter. Or, since this TV also works as a monitor, you could use the converter box video and audio outputs instead. If the TV has a single A/V input jack instead of separate audio and video jacks (the usual case), Radio Shack and other vendors sell the adapter cable you'll need. One might have been supplied with the TV.
Feb 10, 2009 | Coby Televison & Video
I have a Trutech PVS31170S1W LCD Tv,do i need a converter box?
Your tv is DTV ready, it has both an ATSC and NTSC tumer. You can recieve analog and digital OTA (over the air) signals.
You will need to connect an antenna and set the tuning band to AIR not CABLE..
I have provided a link with more information on DTV and Antenna's.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution.  Lone99star
Jan 24, 2009 | TruTech PVS31170S1W 17 in. LCD Television
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
TruTech PLV16190 Television Logo
107 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
