Question about Epson ACULASER CX11NF All-In-One Printer
Epson al cx11nf print problems: Lines on side of output
My cx11nf printer is printer lines on the long sides of the printouts. ie, it appears to have 2 lines of substantially less tone on both the 11" sides of the printouts. Wondering whether this would be a photoconductor problem, toner problem, head problem, ...?
  • scot mac Apr 30, 2007
    Just exchanged the unit for a new one. If the new one has the same problem, i'll try cleaning the laser window. Was worried about the problem being the PCU, and that is the reason i went for the exchange. PCU's are too expensive on this unit ($230-$400).
  • Anonymous Mar 18, 2014
    photoconductor troubel epson cx11nf
  • Epson Master
  • 691 Answers
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
Posted on Apr 29, 2007
  • joanna222 Oct 20, 2010
    Thanks so much!! I did just what you recommended and it worked beautifully!! I am so happy to have a printer that works well again!!
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Hi when i print lines appear in my printout - i have ran the maintenance checks and nozzle check utility seems fine although the black looks a bit fuzzy - do you know how to resolve this problem please?...
If you haven't done so, run the alignment setup again. If that doesn't work, put in new cartridges and see if there are still lines in your printout. This will check if it's a printer issue or cartridge issue. Here's a PDF from epson on how to run the alignment setup. See page 11. http://files.support.epson.com/pdf/r300__/r300__pg.pdf
Mar 01, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson CX11NF-Vertical line on output of adf... Vertical line appears only on output of adf scanned docs on Epson CX11NF printer.
There may be dust or dirt on the small glass strip. Lift the scanner unit so you can see the scanner glass. To the left you will see a small glass strip. That is the area that you will need to clean. Make sure it is spotless as any stuck on dirt will cause the problem you are having.
Jan 27, 2010 | Epson ACULASER CX11NF All-In-One Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
White scratches and a "breaking" mark on printout
Epson CX11NF printer problem-repair solved
To clear stripe....Open the front cover and look on the inside of the right side of the printer....There you will see a pictorial instruction showing the PRINTER HEAD cleaning procedures.
Follow them (remove tab/plug on right side, pull out on head lock arm on inside right, then fully pull out the printer head arm inside the port on the (outside of printer) right side.....Then push it back in, replace tab cover, push the lock back in (inside right-front) and problem solved.....
God Bless,
Happy Epson CX11NF User
Oct 14, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson cx11nf printing problem
on the right hand side of the printer towards the back, but on the right hand portion of the printer there is a tab you can open it is about 3/4 inch wide and 2 inches long. After you pop the tab off, there is a handle. Pull the handle out SLOWLY all the way. This will wipe off the printing head like a windshield wiper. Insert the handle back in slowly, and whallah!!!
Fixed me real good!!!
Jul 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Unrequested characters and nos on top of printed matter
you can try with epson compatibel 9pin from the printer list
Jun 28, 2008 | Epson Dot Matrix LX-300+ II Printer
Light stripe down right side of colour print out
I had the same problem and managed to clear it by cleaning the print head. You can fiind instructions on how to do this in the pdf manual on the Epson web site at ftp://download.epson-europe.com/pub/download/314/epson31436eu.pdf - go to page 351 and it should get you through it OK.
Nigel
May 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Poor printout / colors dont look exactly as they are supposed to
Some of these problems are addressed in the Service Manual p242 onwards with illustrations and correction procedure. You may have to talk it through with EPSON technical support/or obtain a technicians support. What is shown does not exactly fit your description so here's hoping.
Mar 27, 2008 | Epson Aculaser C1100 Printer
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
661 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
