Question about Cuisinart DGB-500 Coffee Maker
Coffee maker won't stop beeping but parts seem to be in place
    Problem Solver:
  • 6 Answers
The beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken.
Posted on Jan 21, 2009
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
DGB-600 won't stop beeping and is missind grinder
The grinder cover has a white pin as a part of the cover that acts as a go between for the plastic molded post on the cover and a contact switch in the unit. Without the cover in place the molded post is not long enough to reach the contact switch and "tell" the machine it's o.k. to brew. It will beep incesssantly and do nothing. Get a replacement cover, or jury rig something to act as a replacement for the grinder cover pin. You can manually push in the switch to get it to stop beeping, but it will spring back out as soon as you release it.
Dec 19, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Beeping will not stop and coffee maker will not operate
The constant beeping means something is out of place. Take out all removable parts and put them back in their proper place (and close the lid when you are done) - should stop beeping after that.
Mar 22, 2009 | Cuisinart Thermal DGB-600 Grinder
Won/t make coffee, beeps and keeps on beeping
all the parts are not properly in place
Mar 14, 2009 | Cuisinart Coffeemakers
I just purchased a dgb 550 series 2 days ago, I was moving it and it is now making a beeping sound and will not allow me to do anything, I have unplugged it and replugged and it still does this I tried to...
The constant beeping means that something is out of place - make sure the charcoal water filter holder is in place, even if there are no filters inside. Make sure the grind chamber and all parts are in place. Make sure the filter basket is in place, and that the door is closed. Finally, make sure the lid of the coffee maker tiself is shut and that the lid of the craffe is firmly in place. If everything is in place, it should stop beeping. Turn the coffeemaker off, and then on after all of this is done.
Mar 08, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
My cuisninart won't stop beeping, but every part seems to be in place how can I fix the problem?
On the Grind and Brew coffee maker the beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken. If you open the cover after you have started the auto-brew, it will beep but you can stop the sound by using a pen to gently depress the switch inside the small plastic post.
Dec 29, 2008 | Cuisinart DGB-500 Coffee Maker
ANNOYING BEEPING SOUND
If not all is fitted in place the it will beeping until all is in place.
Jul 28, 2008 | Cuisinart DGB-600 Coffee Maker
Won't stop beeping
Every part must be snuggly in place.  I took the removable parts out and put them back a second time, and that did the trick.  I must not have had everything in 'just right'.
Apr 25, 2008 | Cuisinart DGB-300 Coffee Maker
DGB-300 10 cup grind and brew
The constant beeping means that something is out of place. Take apart the coffeemaker parts completely and put them back in their proper place (don't forget to close the lid). The beep should stop. If it doesn't stop, unplug the unit for one hour and call Cuisinart to see if it is still in warranty.
-Tha Mp3 Doctor
Dec 17, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
202 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
