Question about Cuisinart DGB-500 Coffee Maker
My cuisninart won't stop beeping, but every part seems to be in place how can I fix the problem?
    Problem Solver:
  • 6 Answers
On the Grind and Brew coffee maker the beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken. If you open the cover after you have started the auto-brew, it will beep but you can stop the sound by using a pen to gently depress the switch inside the small plastic post.
Posted on Jan 21, 2009
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
The fridge shut down it keeps beeping i how do i stop the beeping and make everythig cold again disconneting doesnt help
Turn off alarm if possible. Find out what won't run then fix it or based on your question call a local experienced family repair service your friends would reccomend.
Aug 13, 2011 | Frigidaire Refrigerators
When i turn my syncmaster 2233 computer, it turns on but it makes a beeping sound alot of times and it won't stop.. I usually fix it by turning the power cable on and off and it will stop the beeping...
Remove the memory (RAM). Clean its contact points by an eraser. Fix it. If it does not work, try using another slot. If it still does not work,replace it with new.
sonsunny
Jun 14, 2011 | Computers & Internet
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Beeping will not stop and coffee maker will not operate
The constant beeping means something is out of place. Take out all removable parts and put them back in their proper place (and close the lid when you are done) - should stop beeping after that.
Mar 22, 2009 | Cuisinart Thermal DGB-600 Grinder
Beep will load is running
This sounds like the same problem I had. It turned out to be a loose solder joint on the potentiometer for the water level. A few minutes with a soldering iron and it was fixed. I'm not an appliance tech but as near as I can tell, any input from any button or knob will turn the machine on and/or create a beep. Therefore, a loose connection at various places on this board could cause the same problem. I have also read about a lot of control board problems with various kenmore appliances. I suspect many of them may have a similar cause. Hope this helps.
Mar 19, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Broken hinge on reservoir cover for Cuisninart model DCC-2200
The hinge itself is not orderable, but a lid with the element that fits into the hinge was available from Cuisinart the last time I checked. Call 1-800-726-0190 to be sure. It is not easy to put the replacement lid into the right place without breaking the part, but it is possible - you have to put one bar into the hinge, and then pull the other bar just enough to fit it into place without breaking it. If you are out of warranty, the lid will cost somewhere betwen $15 and $20 with shipping.
Feb 26, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
734 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
