Question about GE JTP20 Electric Single Oven
GE Wall Oven JKP70 Locks and reads F9
When I use my GE Wall oven at temps higher than 400 or broil after about 15 minutes the disoay reads F9, LOCKED. After 30 minutes I can use it again as long as its 350 or less. The oven is rarely used and only one year old. Also the control panel gets really hot.
  • TraceyO Feb 27, 2009
    After using the broiler on my GE wall oven this evening, I had turned it off. After a few minutes, it started flashing "locked". The upper unit got very hot, although the oven was not on and there was a ticking sound behind the panel. You couldn't open the door or use any of the buttons on the panel. Finally, we had to turn the power off to the oven as the front unit seemed to be getting hotter. We tried turning the power back on after a few minutes, hoping it would have cleared itself, however, the problem still exists. Any suggestions would be greatly received. The oven is 13 months old.
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
Posted on Dec 30, 2008
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
JKP70-27" SINGLE CONVECTION WALLOVEN
Replace the transformer and hope nothing else went bad. Good luck!
May 27, 2014 | GE JKP70 27" Single Electric Wall Oven...
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Old GE wal mounted oven Model J55BE-1
I have the same problem. Did you ever find the solution
Oct 05, 2008 | GE Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE JTP20 Electric Single Oven Logo
350 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
