Question about Samsung BlackJack II Smartphone
My blackjack 2 just turns off
The phone will periodicaly just turn itself off for no apparent reason. I thought it was just when the battery was low, but that is not the case. Any ideas on what might cause it short of a defect?
  • 1 more comment
  • Anonymous Feb 20, 2009
    I have the same issue. My BJII will also just turn off the service and keep the phone powered on. I have not been able to find a solution for either issue.
  • Anonymous Apr 01, 2009
    I, too, have had that probem. The next symptom is for the sound files (your ringtone files) will be corrupted and the only fix is to get a new phone. Make sure you have the water damage indicator checked before you send it in or they will claim they do not have to fix it b/c of water damage but this is not the case... It will suddenly become water damaged when they receive it.
  • Anonymous May 07, 2009
    i have the same problem and just keeping the keypad locked works a bit but it still turns off even when its locked just not as much
My blackjack2 does the same thing. The phone service just turns off automatically every now and then. It is so annoying. Except for that glitch and the fact that it likes to freeze sometimes, i love my phone. I wish these problems can solved. Do u think it might be a problem with the battery? Highly doubt that because the battery life is still long. But it is a year old and I have put the battery in the freezer several times before when i couldn't find my wall charger. I was hoping someone would tell me that yes, it could be a battery problem so that I could go ahead and buy a new battery for it.
Posted on Apr 30, 2010
I found that when I locked the keys, it stopped shutting itself off. I guess I was hitting the power button or something. I just keep the keys locked all the time now, except when I'm using it. Hope that helps.
Posted on Jan 07, 2009
My phone turns itself off!
It might be the battery problem. Try to change to a new battery. If it is still the same, try to reformat it or just reset it. It might be the software problem.
May 09, 2010 | Motorola Mobility RAZR V3
Blackjack 2 simply will not turn on!
Mine did this after being dropped. I worked on it for a long time- finally got it to come on...then had to turn if off to fly. I spent a long time trying to figure it out....I am no tech expert- just an athletic trainer so to me if I drop it something must have shifted so...I tried to fix that. I took the back and the power button off (the power button has a small stretchy loop attached-- do not tear this or you can't get it back on- you need to loosen up the key and tilt it back and down to unloop it). There is then a small "power button" that gets clicked under the big one. The contents of my phone had shifted so I gently pushed the button down and forward into the phone (I actually tried severally directions). It does not have to be forceful- I was very careful. And "poof" my phone turned on and I am much happier. ;) Then you just re-attach the loop and you are set. I hope this helps anyone looking for answers- I couldn't find any other suggestions anywhere that were sucessful for my situation. I now do not have to spend money on a new phone. :)
Mar 27, 2010 | Samsung BlackJack II Smartphone
My phon turns offf and whev i turn it on it shuts itself right off
Try doing a hard reset or reformat your phones memory card. Turn phone off and hold the directional pad UP while turning the phone back on. Follow directions on screen. Also try taking the battery and SIM card out for 20 min and then put it back into the phone. There are two patch's avalible to download to update your phone. Click on the link below to download the Blackjack II user manual and patchs:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=01010100&prd_mdl_cd=&prd_mdl_name=SGH-I617
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=61120
http://www.modaco.com/content/i617-i617-modaco-com/262115/hard-reset-the-blackjack-ii/
Mar 05, 2010 | Samsung Clear Pink Hard Case for ...
There is a yellow blinking light on my Black jack
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II charging problems
Apr 22, 2009 | Samsung BlackJack II Smartphone
Blackjack 2 won't turn on
Hi svstskier,
This is actually a bug in the BlackJack II's firmware. If you power the BlackJack II off, but you're unable to power back on, try removing the battery for about 10 seconds, then reinsert the battery and power back on. The power button should work now.
(At the moment there's no permanent fix for this.)
Does that adequately resolve the issue?
Are you turning the BlackJack II off to conserve battery? While flying? Something else?
Thanks!
Jonathan
Sep 28, 2008 | Samsung BlackJack II Smartphone
Low storage space
IMEI: 357445-01-595676-2
Aug 08, 2008 | Samsung BlackJack Smartphone
Blackjack cell phone AT&T won't charge or turn on
Go back to AT&T, or find somebody else who has a Blackjack II and put thier battery in the phone to see if this 'jump starts' it. I have had the same problem now 3 times. There seems to be a consistent issue with Blackjacks just not charging after a while, then the battery runs down and you can't turn the phone on again. 1st time AT&T put a new battery in mine and it turned straight on! 3 weeks later it happend again and they gave me a new phone AND another new battery. 3 weeks later the same thing has happened again with thenew phone. Never seen this happen with any other phone model.
Jun 26, 2008 | Samsung BlackJack Smartphone
My samsung blackjack 2 will not charge. the battery is now totally dead, will not turn on and will not charge even with the wall outlet charger or the computer usb charger. when the phone still had some...
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Jun 09, 2008 | Samsung BlackJack II Smartphone
Can't turn off ALERT - battery low
taking the battery out should do it. Or maybe just turning it off. To take out the battery, just take the back cover off and pull the battery off.
Nov 19, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung a570
nope i had 1 an i threw it in the wall twice it comes up and work but even on a full bat it shows low bat....(it never dieed nor turned off)
Jan 02, 2007 | Samsung SCH-a570
Samsung BlackJack II Smartphone Logo
723 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
